retrofit a 74-75' GMC grill in my 78' k5?
Discussion in 'The Garage' started by ncgamedog, Mar 17, 2006.
  1. ncgamedog
    ncgamedog 1/2 ton status
    Oct 7, 2005
    130
    union grove, north carolina
    i was looking at it and the GMC grill is alot deeper than my bowtie grill. i could remove the hood latch support and trim the outer supports to make it fit, but i am worried about weaking the flat pan (or what ever you call it) at the top. A lot of butts and bellys rest there while wrenching under the hood. i can't see a clean way to re-support it after its removed. has anyone ever tackled somthing like this? and finding new or junkyard parts for 74-75 is like pulling teeth. no on LMC or chevy duty:( i checked. thanks - justin
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Did you try JC Whitney, just for the hell of it?
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What the difference is with both GMC and Chevy is from 73-76, the grill's were deep. In 77 they started using a shallower grill. 77+ grill's will fit in a pre-76 rig, but not vice versa.
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    Also, 73 & 74 grills are different from the rest. They are not flat like the later years.
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Find a 74-75 core support and hood latch and swap all of it. Junk yard time.
  6. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    the center grille vertical support is different too and the hood pull handle changed locations, cut out in the grille
    good luck
