return line for fuel injection on '73 blazer
Discussion in 'The Garage' started by boots, Feb 27, 2006.
  1. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    Scored a HOlley projection unit all sensors holley intake software etc etc etc, though I did have to go out and buy a fuel pump block off plate oh darn! I have a whole $10 invested in the works. Planning to put it in my '73 when/if I ever get a chance. I'm curious as to how to run the fuel return line. It's been a while since I've had a chance to work on it but I don't recall a return line on it. if there isn't how'd ya'll run your returns? My current thoughts are:
    T into the vent line that goes up to the cap
    T into the supply line between the tank and the electric pump
    weld a bulkhead fitting onto the tank itself for a fitting
    all those are assuming I'm not forgetting there was a return line off the pump
  2. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Don't T into the supply line.
    I ran 3/8" ID fuel line for the supply and the return, the minimum ID for the return is 5/16". Mine is an 86, so it had a factory 1/4" ID return line, but 1/4" is too small for a high flow fuel pump and will result in back pressure at the outlet of the throttle body (not good).
    I removed the fuel tank on mine and drilled a hole in the top of the tank and installed a bulkhead fitting for the return. To be safe I sponged all the fuel out of the tank and then purged it with CO2 before I drilled it. Drilling a steel tank full of fuel vapor is a bad idea.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I did it on my '75 when I went TPI. Just removed the sending unit and drilled an extra hole, then added a bulkhead fitting there. I used 5/16's steel brake line to make the run along the frame from the engine back to the tank.
  4. boots
    Nov 3, 2002
    183
    Well my tank has been out for almost 5 years in various weather conditions. Planning on using a tank prep/sealer from eastwood to recondition the insides. Heck right now I'm not even sure where my sedning unit is but I can pull one out of my '75. Drilling/welding shouldn't be much of a problem, can still purge it with CO2 or 75/25 welding gas if you think appropriate. Anything else I should do in the rear while i have the tank out? already swapping body mounts and installing hitch.
  5. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    The bulkhead in the top of the tank is the way to go.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I "t'd" into the fuel filler neck.Made a "T" with a barbed fitting screwed in place.Then I ran a piece of rubber fuel line from the 5/16ths hard line to the "T"
