return line question
Discussion in 'The Injection Section' started by leadfoot067, Jul 9, 2006.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    im injecting my 73 K5 and i need to run a return line...i noticed the factory vent line is there can i use it? has anybody used it for return?
    thanks
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I would run a new return line and leave the vent line hooked up or you run the chance of imploding the gas tank (sucking in).
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    could swap in a newer sender unit with return in it.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i ran mine to the vent line hole, that line is only for the carocle canister the tank is still vented through the cap if it is the older style. Or you can run a t- fitting in the filler tube to put a return line in if you want to keep the canister
  5. leadfoot067
    May 14, 2001
    1,563
    ya the cannister line is the one im speaking of....mine hasnt had a cannister since ive owned it....as i do more reading into the subject it seems most return lines are 5/16...so mabe it will work...iwas simply trying to avoid running more lines....
  6. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    On my '77 the original return line (or charcoal canister line) was much smaller than the factory TBI return line so I changed it out to the factory TBI line. The old one couldn't flow enough.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    When I added the line on my '75, I just ran a new line and drilled a new hole in the sender plate. If there's room, you could use a bulkhead fitting, but I just had a buddy TIG weld mine in place.
