"Return-to-center" steering stabilizer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Feb 16, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    \"Return-to-center\" steering stabilizer?
    Is there such an animal? I' believe I've read about them but do they make them for a K5 apllication? My existing stabilizer shock just holds it's position wherever that might be, and I was wondering if a return-to-centre would be better....
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Re: \"Return-to-center\" steering stabilizer?
    Some on here have had good results with the 4-way coilover stabilzer. I just installed one on my '74 2wd, that runs 35" tires, and it didn't help very much. It still doesn't return to center well and still wanders all over the road. It may be my cheapo tires, I'm not sure..... You can see one here: www.jmartin.net/goose
  3. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I thought the return to center problem was a allignment problem. mine returns fine with 32" and 2 1/2 lift
    <font color=red>Let me at it I can break it</font color=red>
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Mine works great - like any coilover you've got to screw with the spring a little bit to get it fully functional though. I found that ½ a turn of torsion on the spring gave it a much stronger return impulse.
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    If you want more return to center, shim the front pinion down. This will increase caster. You could also add more tow in, but this will increase tire wear (rotate often if you do). I can let go of the wheel at 90+ on mine and it tracks fine.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    could be kingpin time
    formerly 77chev
    still a jerk though
