Reuse U-bolts
Discussion in 'The Garage' started by IDGMC, Mar 14, 2006.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    I put a lift on my truck about 6 months ago. I'm about ready to do a 3/4 axle swap. Can I reuse my u-bolts from the front 10 bolt on the dana 44? or should I spend 20 bucks and get new ones?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    u can reuse them if they arent that old. over a couple years old, id get new ones, but you should be ok
  3. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Spend the $20 and get new ones. When in doubt, throw it out.:D
  4. orangeGMC
    orangeGMC 1/2 ton status
    Dec 26, 2004
    184
    Connecticut
    where's a good place to get new ones?
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    buy new ones
  6. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    local spring shop.
    take your old u bolts as a guide.
    usually pretty cheap.
    i got 4 5/8 u bolts ( most aftermarket lift kits come with 9/16 bolts) for 36-40 bucks.
  7. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I think AutoZone has leaf spring/axle u-bolts for about 15 bucks per pair.
  8. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    yes they do.
    most i saw were 7/16 or 1/2
    which in my eyes, is way too small.
  9. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Another thing to think about is when you buy new U bolts I would make sure there is enough thread to maybe install a 0 rate in the future. A lot of guys cut the threads off or get them just tall enough for there current springs and have to buy new ones down the road.....
  10. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i wouldnt try it. i almost lost a dana 60 with 38" tires on it one time.
    and the auto zone ubolts are not great quallity let the ricers have them.:eek1:
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Some older Dana 44 front axles have smaller diameter tubes and it will make a difference in your u-bolts. Measure the tubes and compare to the 10 bolts before you purchase. The 10 bolts all have the larger tubes ( thinner but larger ) but D44's vary in wall thickness and outer diameter over the years and applications.
    Tom
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You read my mind ;)
    IMO, re-using u-bolts isn't a good idea. However, that doesn't stop me. :D I've found the fine-thread u-bolts get messed up easily - whereas the coarse thread ones last better for repeat installations. Did I just say that? :o
  13. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    Spicer will tell you not to reuse em, yes I've actually talked to them about it. California tow truck association will tell you the same thing. If we drop a drive shaft to tow a vehicle we refuse to put the shaft back in because we are not to reuse the straps or the bolt unless the parking brake is shaft mounted then we put a big note on the steering wheel for the mechanic to replace em. There was a write up in one of the Tow magazines about this a while back, course for us it our butt if something fails and we have put it back in
  14. mrhoes
    mrhoes 1/2 ton status
    Jul 20, 2002
    123
    Austin, Texas
    I tried to get some u bolts from my brothers welding teacher, and he made a big deal about that they should only be used once and then thrown in the scrap bin. As long as there is nothing wrong with them I just reuse u bolts.
  15. old blaze
    old blaze Registered Member
    Feb 11, 2006
    6
    Georgia
    Getting old U-bolts off is not the problem but putting them back on they tend to break. I know this from trying to reuse them on my Jeep, rather than risk time and trouble get new ones.
  16. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I have reused u-bolts again, but they where pretty new to begin with. I am not going to put a new set of u-bolts on my truck, and then if I need to remove them to redo something a few days later, I am not going to throw them away. One thing I do is tap the threads before I put them on because the threads on u-bolts always get torn up a little when removing the nuts.
  17. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    i just got a set of 4 new 5/8 ubolts w/ hardware and spring center pins for 45 at my local spring shop
  18. UD0MEILLD0U
    UD0MEILLD0U Registered Member
    Oct 12, 2005
    37
    Gainesville FLORIDA
    I just did a 12 bolt to 14 bolt swap and was able to reuse everything but my old rims! =). My only question is what (or is there) is the torque setting for the u-bolts. My U-bolts nuts are 24mm's. Ya they are HUGE! My truck has 6inch superlift lift. Thanks!
  19. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Replace them. I keep a few old ones for trail spares.
  20. goldwing2000
    goldwing2000 Guest
    If you bought new ones when you did the lift 6 months ago and they are the same size as the ones you're going to need now, I don't see any reason you can't reuse them. U-bolts aren't torque-to-yield, so as long as they aren't damaged, you can reuse them.
    Put a straight edge along the threads to make sure they're not stretched and you should be good to go.
