revers cooling on a 93 1 ton?
Discussion in '1992-Present Chevy & GMC models' started by great scott, Jan 21, 2004.
  1. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    sorry the search function is not working and i need to know about revers cooling did it come on 93 1 tons, whats siffrent about them? /forums/images/graemlins/confused.gif
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    You should have a reverse rotation water pump. It is needed because of the serpentine drive on the engine. Both SB and BB have it. The only engines that have reverse cooling would be LT1's. Doubt that you have that in your C/K3500.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    nope.. no reverse cooling on a 93 one ton chevrolet truck.. LT1 engines had reverse cooling, and optispark (yuck).. both of those things make parts availability rather limited..
  4. great scott
    Dec 31, 2002
    333
    Utah
    thanks for the info and confirming what it is. now how do i fix the thing? after it sits for a couple hours then i run it and it will over heat one time then the temp drops and stays low (arond 150). i installed a new t-stat, and water pump but they did not help
  5. Confedneck
    Nov 1, 2002
    5,236
    are you sure its overheating? or is the gauge just reading hot? i would try bleeding any air out of the system to start..
  6. great scott
    Dec 31, 2002
    333
    Utah
    yes it is overheating, I can even hear it boiling out the over flow. But I have never knowen a truck or car to over heat and then drop below normal temp. This stupid thing is really getting to me. /forums/images/graemlins/confused.gif
  7. Confedneck
    Nov 1, 2002
    5,236
    if its overheating, boiling out, are you sure its not just air coming out??
  8. great scott
    Dec 31, 2002
    333
    Utah
    I have an inferred temp sensor from raytek and it reads about 250 deg on the t stat housing.
