Reverse Flip Shackles
Discussion in 'OffRoad Design' started by BrentNClemson, Oct 23, 2002.
  1. BrentNClemson
    BrentNClemson Registered Member
    Oct 7, 2002
    10
    I've got a 6" susp and 3" body lift. My front tires are rubbing...well....tearing apart the metal... Would it be possible to put the ORD shackle flips in the rear, leave the blocks, and get a 4" shackle for the front?? If so, whoa makes one for the front? I'd like to avoid getting all new springs...but I don't want it to be too crappy. Thanks. /forums/images/graemlins/ears.gif
    -Brent
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You realize that in order to get 4" of lift in the front out a of a shackle, they'd have to be 8" longer than the ones that are there now? It won't work, for many many reasons. You can get a max of about 1.5" of lift out of a shackle in the front (3" longer), more than that and you'll have problems. /forums/images/graemlins/tongue.gif
    What size tires are you running that 9" of lift won't clear them? Sounds like you may need to do a bit of fender trimming...</font color>
  3. BrentNClemson
    Oct 7, 2002
    10
    Well I was referring to the ORD reverse flip shackles, which claim a 4" lift using the same springs. I've got 39.5" TSL's and the other day they bent back the fender pretty good and took a chunk out of the tire. I'm just lookin for a way to get a little more lift. I dunno, ORD says you can get either 2.5 or 4 inches, so maybe I could do the 2.5".
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That part must have thrown me... </font color>
  5. BrentNClemson
    Oct 7, 2002
    10
    Oh okay sorry about that. So in order to get 4" in the front the shackle has to be 8"? Hmm...well that won't work. Thanks for the info.
    -Brent
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The shackle has to be 8" LONGER than it was; since you're only lifting one end of the spring it has to go twice as far as you want to lift the axle, since the axle is in the middle of the spring. Yeah, it won't work. /forums/images/graemlins/grin.gif </font color>
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what part of the metal are you tearing up? i have 39.5's with about 6" of lift and i am fine...
  8. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Joel (The General) was running 39.5X18 boggers with a 6 and 3 lift and he hit his front fenders too. His fenders were only cut back to the inner with the inner uncut. He took a outside lug off as well. Cutting the fenders back more and taking out most of the inner should work.
    OPS hit the wrong reply button /forums/images/graemlins/eek.gif
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    right, but this guy is running TSL's that are 15" instead of 18.5" wide
  10. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You can do the flip in the rear, but for the front you'll need a new spring to get that kind of lift from it.
    Sounds to me like time for the sawsall. You can tell that's the consensus from the rest of this crowd also. Some are more saw happy than others but we all make the truck work then put the tire size we want under it. If the sheet metal has to leave to fit the tires, off it comes. I'd look into that method before more lift since details like driveshaft angles can get really hard to deal with as you go higher.
