Reverse flow water pump
Discussion in 'The Garage' started by mrk5, Apr 30, 2004.
  1. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    What's the difference between the standard flow and reverse flow water pumps. I'm going from v-belt to serpentine and the new pump is reverse flow. Will I need new fan and clutch? /forums/images/graemlins/dunno.gif
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] I may be mistaken but just turn your fan around, I see no reason why you would need a new clutch.
  3. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    That's kind of what I was thinking. Seems like it should work. /forums/images/graemlins/dunno.gif /forums/images/graemlins/thinking.gif
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will need a new fan, just turning it around will do nothing, think about it. also the pump is reverse rotation not reverse flow, reverse flow pump push the water through the heads and to the block, standard goes to the block first then to the heads.
  5. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    Yeah, rotation. /forums/images/graemlins/doah.gif
    The clutch should be okay thought shouldn't it?
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea i don't think the clutch matters which way it turns
