Reverse light activation with manual..
Discussion in 'The Garage' started by mtrdrms, Apr 23, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I just swapped my 700r4 for a sm465 in my 87. I am curious about the reverse lights. the plug that went into the top of the 700 is that the backup light switch? Do I just plug that into the 465 and call it a day? Right now my reverse lights do not work. Can someone tell me how to get them going again? Thanks. Andy
  2. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    The reverse light switch is a ) shaped switch on the top of your steering column with 2 wires. (purple and green maybe if i remember right?) The 465 trucks have another harness that takes those wires to the plug on the top of the 465.
  3. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    mtrdrms- Sorry to highjack, but I am about to do the same swap in my '87. I found a good 465 w/ NP205. How bad was it? I have never pulled a tranny and was wondering what all I need. Again, I know nothing about this and I have no clue about bellhousings, etc. Any tips would be very much appreciated.
  4. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    Where do I get this harness - from Chevrolet? Or a doner truck?
  5. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    I would suggest parts rig that had the 465 to begin with becuase of all the tidbits that you need. FOr instance, the bracket that holds the clutch pedal adn brake pedal and the clutch, bell house, flywheel, slave, master cylinder adn reservoir. Oh and the harness that connects the reverse light switch to the 465 :mad: other than that let me know what your questions are and I will try to help you through it man - Good luck
  6. wforicv
    Feb 16, 2004
    165
    mtrdrms
    Thanks for the info. Keep yall posted.
