Reverse lights don't work in MT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87K54WD, Mar 23, 2000.
  1. 87K54WD
    87K54WD 1/2 ton status
    Mar 23, 2000
    105
    Texas
    Reverse lights don\'t work in MT
    My reverse lights don't work when I put the MT in reverse. I'm looking to get this fixed tomorrow at a GM dealership. I got this truck from my uncle and he believes that it stopped working after getting the MT serviced with a new clutch. Did the shop forget to put a wiring harness back together? Any help is greatly appreciated. I would like to try to fix it myself tonight if possible. Checked the fuse and bulbs and they are fine. Any idesas on how much the dealership might charge me? Any ideas/advice/suggestions on the fix? Thanks
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Re: Reverse lights don\'t work in MT
    There should be two wires in the engine compartment that go to the transmission reverse switch. I believe it will be on top of the tranny and come up closer to the passenger side. The wires will be dark blue and light green.
  3. 6.2 man
    6.2 man 1/2 ton status
    636
    Curtis , WA
    Find the connector on the transmission switch and use a jumper wire to connect them together . If they work the switch is bad . If not check one side of connector to see if it's hot . If it is than sounds like bad wiring or bad bulbs .
