Reverse manual valve body? What does it do? Advantages?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cybrfire, Nov 15, 2003.
  1. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    also, Where would I buy a rebuild kit for my trans. My brother has done a few of them and will do mine but I got to get the parts.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    reverse manual valve body allows you to select the gears in order in an automatic transmission, it changes the shift pattern so if you have a floor shifter, i believe the pattern becomes 1,2,3,D, instead of D,3,2,1. or what have you.. you can pickup a transmission rebuild kit at any transmission shop or your dealership..
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    A benefit to the reverse pattern (P-R-N-1-2-3-4) is if you are stuck in a mud hole you can easily go from first to reverse to rock yourself out.
    Also while shifting under hard acceleration you are less likely to hit reverse as opposed to 3rd or 4th since you are shifting away from reverse.
  4. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The last rebuild kit I bought, I got through Northern Automotive in Sioux City. Fast shipping, and good prices. Might check on ebay, too.
