reverse maunal valve body ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Oct 10, 2002.
  1. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    ok first off would it be any good on a daily driver? and does it switch you from
    P-R-N-D-2-1 to 1-2-D-N-R-P or from P-R-N-D-2-1 to P-R-N-1-2-D
    get what i'm askin? does it reverse everything or just foreward gears?
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    P-R-N-3-2-1 From this
    P-R-N-1-2-3 To this
    The idea is when wheeling you can quickly go from 1 to N or R to N or even 1 to R in a hurry.
  3. muddysub
    Jun 23, 2001
    10,454
    493
    yeah cool! /forums/images/graemlins/pimp1.gif is it any good on the road? or is it an inconvenience?
    [stupid question mode] there's no clutch pedal involved right?[/stupid question mode]
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You absolutly DO NOT want this setup on a column shifter for street use (or trail use for that matter)!!!!! Its WAYYYY to easy to miss gears, you need the precision of a full ratchet shifter like B&M or Hurst (or an Art Carr for some of the upper class folk /forums/images/graemlins/grin.gif.)
  5. CK5
    May 19, 1999
    21,627
    704
    CO
    On the road? I don't drive on the road much anymore but it's not to bad and no clutch pedal.
  6. muddysub
    Jun 23, 2001
    10,454
    493
    so i would wanna ditch the column shifter huh? how much would it cost to have my th400 switched to reverse manual and a nice floor mounted ratchet shifter.
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    I've allways wondered if you have to manually shift all gears or do you still have the "drive" combination at the third position? Thanks,
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    FULL manual
  9. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    There is a vavle body modification called automatic/manual which goes full manual when you drop it into L1, but will retain the automatic driving when you put in in D.
  10. muddysub
    Jun 23, 2001
    10,454
    493
    /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif anyone else heard of this? that would be pretty cool.
  11. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I just priced a crap load of stuff from Art Carr for my TH400 and the reverse manual valve body was one of them. If you feel like spending $349 it can be yours. I would recommend a reverse gate cable shifter if you plan to go this route.
  12. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Yeap. The street car guys know all about this. Car Craft magazine is a good source of information on such things. It's not available for 700R4s though to my knowledge (I'd like it on my 700). Just 350s and 400s. Get a transbrake and you'll be the talk of the town. /forums/images/graemlins/shocked.gif
  13. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Also available for the 700 r-4's, but it is about $100 higher.
  14. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Do you know who makes it? I'd like to turn a 700R4 into a full manual valvebody. A transbrake would be nice too.
    I'm sure one of these days my 700 is going to die so I might as well head it off. The only thing that pisses me off is that ratchet shifters are so expensive and 4speed ratchet shifters are doubly so.
  15. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
  16. CK5
    May 19, 1999
    21,627
    704
    CO
    Be careful, as far as I know Art Carr has the only manual valve body with compression breaking, which you want for off-road use.
