reverse mount motor help!!!!!
Discussion in 'Center Of Gravity' started by dustinellis, Jan 24, 2004.
  1. dustinellis
    dustinellis Registered Member
    Oct 30, 2003
    31
    south texas
    Ok, it a 83 k30 4-linked with unimogs.The kicker is the motor is mounted backwards in the frame about midship,now evrything turn backwards we thought we could fix it by turning a div.mount t-case backwards and mounting it in the front of the truck and running it to another one directly under the tranny.WRONG because with the t-cases backwards there is no output for the front axle.Plan two was to mount another case under the tranny facing the the right way behind the one moounted backwards giving you an out put for the front and the rear still it tuns backwards so now the plan is to swap portals from left to right to get the truck to go the right direction without getting a drop box made $$$$$.any other ideas???
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Run a shaft from the output of your transmission to a boat v-drive. Then a short shaft back to the middle of the truck to a divorced t-case mounted like normal and then shafts to the axles. The V-Drive reverses the rotation direction.
  3. CK5
    May 19, 1999
    21,623
    701
    CO
    Couldn't you simply grind the shift rails on a NP205 for independant front and rear output?
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Might be easiest to modify the axles. Any other way would get complicated and create more breakage points.
  5. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    it appears that his problem is that the rear output of the T-case which is the now front ouput with the reversed drive train. is that it is rotating the wrong way or is it too far off center cause clearance problems? We need pics too.
  6. dustinellis
    Oct 30, 2003
    31
    south texas
    i will try to get some better ones this was when we were working on the suspension. pic of the truck
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Actually yeah, im pretty sure you only need a cam and oil pump, not a bad idea. /forums/images/graemlins/thinking.gif
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    no workie
    then you have to find an automatic that works backwards. or if running a standard remove all the gears from the shafts and install them backwards to get the helical cuts going the right way. the best way is the v drive off a 2wd tranny into a t case.
    easiest way in my eyes as well.
    Grant
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I also agree on the v-drive. Get a casale v-drive box and be done. They can hold alot of hp stock, and can be modified to hold well over 2,000 hp.( I run one in my boat, and my motor is installed backwards)
    Dan
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    OK, I am going to go out on a limb here and ask WHY? WHy mount the engine like that in the first place and cause all these headaches?
  12. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It's the latest craze! Putting the engine in the back makes for excellent visibility out of the front.
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Next it will be electric motors at each corner and a small generator to keep the batteries charged. /forums/images/graemlins/deal.gif
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd like to make a mid engine setup, so you can sit all the way in the front. Would make for one short rear shaft though.
  15. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    wow me likey, just needs a speaker and tape player for the v8 sound...
  17. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
