Reverse rotation d60 crrier the same as a standard rotation?
Discussion in 'The Garage' started by TX Mudder, Jan 27, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I am looking at buying a detroit from a reverse rotation ford d60.
    Is there any difference in carriers that I need to be aware of?
    -- Mike
  2. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    All high pinions used the 4.10 case so yes thay are interchangable if your using the right ratio
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Are you trying to use ford carrier in GM housing? /forums/images/graemlins/thumb.gif Look fo Its finally done-- my massive dana60 article.last posted 1-26-03 in garage. /forums/images/graemlins/thumb.gif
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Isn't the term "reverse rotation" a misnomer???
    I thought some were "reverse cut" but they all rotated the same way.... /forums/images/graemlins/confused.gif
    Maybe I'm thinking that some run against the "drive" side of the ring gear and some on the "coast" side???
    .....man, there's still SO much for me to learn!
  5. ZonkRat
    Jan 16, 2003
    1,003
    I think you are right bout cut verses rotation.The reverse cut pinion runs on upper side of axle center line,while reg cut runs below center line and both axles have to turn the same direction. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  6. ZonkRat
    Jan 16, 2003
    1,003
    Acording to chart in mentioned article,the carrier should work if your gears are 4.10s.Carrier #s don't list cut as different,just gears.Best article on 60s I ever seen.Need to copy it. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    From my understanding there is no difference between a reverse and standard rotation carrier. The ring and pinion and housing is what makes the difference between reverse and standard rotation.
  8. ZonkRat
    Jan 16, 2003
    1,003
    The pinion runs on the same side of the carrier in both types.Reverse cut run above center line of axle,others run below the center line.Rev Cut is supposed to be stronger in fronts cause puts power on load side of gear.Reg cuts in front put power to coast side of gears. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  9. ZonkRat
    Jan 16, 2003
    1,003
    This might make sound better.Rev cut gear pulls pinion into ring when power is applied.Reg cut pressure pushes pinion away from ring gear. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
  10. TheLakeRat
    Nov 29, 2001
    363
    Reverse cut and reverse rotation are both terms that have been used (even by myself) but they are both wrong. The corect term is High pinion. And yes they are designed for front applications only. I personally run one in the rear of my Heep and have no problems but it is true that because of the tooth design that it isn't as strong and a low pinion D60.
  11. ZonkRat
    Jan 16, 2003
    1,003
    They're supposed to be stronger in front,a little weaker in rear.In light vehicle it's plenty strong in rear. /forums/images/graemlins/thumb.gif
  12. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I've decided to skip the detroit and save up for a lock right. Right around $300, or the same price as my rear detroit was. No clutches and it's a drop-in? Sign me up.
    -- Mike
  13. ZonkRat
    Jan 16, 2003
    1,003
    Is detroit still available?I want one in my truck.HiPin D60 SFA under 88SWB.How much? Mabey I can afford it.Thinking bout welding it and getting OX Locker later. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer on 38s in TENN. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
