Reversing shims
Discussion in 'The Garage' started by BowtieRed, Apr 3, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    I have 3" blocks and shims- both angled. this angle combines to make my blocks sit back at an angle. I was wondering if i flipped my shims around if it would help this angle? I know it would help the angle, but could i do that safely?
    http://www.customtruckshowcase.com/forum/showthread.php?s=&threadid=6022&highlight=block%2A
    or maybe i could flip the block around? i'm not too concerned with the pinion angle. . as long as it's drivable
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    maybe you could reweld you spring perches to the correct angle, and get rid of the shim.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    no welder. . . no working angle grinder. . . so anyone else, think that would be safe?
  4. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    when i added my ORD shackel's for more lift i also had a angled block. my pionon angle was terriable, so i turned the block around and it was all good.
    so if you are asking if you can run a block backward's and it will work,,,, i would have to say YES.
    dave
