Revisit: Best Dry Lube
Discussion in 'The Garage' started by BadDog, Mar 21, 2005.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    There was a discussion a while back about square drive shafts and the high coeff of friction of dry steel on steel. Specifically, how it related to my series of broken transmissions that resulted from bent springs and the axle moving forward rapidly while under torque load.
    There were several suggestions for various lubrication options, but some of the "paint on" dry lubes discussed in this thread look great but I have no source? Any ideas or other options? Something that will hold up more than one or 2 trips would be nice. Some day I'll order a HAD, but I just can't afford it right now (though it would undoubtedly be better than wasting another transmission... :crazy: ) and I like the "can't hurt it" square shafts... Plus, I like that I built them myself along with everything else on my truck. :D
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you can get the right thickness, you could try that plastic stuff (UHMRE or something like that) that is on harleys body. i would think it would hold up, if you can use if for hawse fairleads and such.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    all of the guys that I wheel with just put alot of grease around the tube, there is also some graphite paint you can use, you can get the paint at any hobby store.
  4. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    yeah, get with a plastics manufacturer and see if they can get/make you some UHMW-PE tube in the size you need. Baring that, how about just polishing the snot out of the shaft and then painting it with graphite paint? Best el-cheapo solution I can think of...
    j
  5. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Russ,
    Why not just tap the outer square tube for a zerk fitting?...Maybe do 4 of them (one on each side)..... :dunno:
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    This stuff. I used a very similar product in my last job, to smooth the shifting action of transmission top covers. You may be able to find it cheaper somewhere else; aviation suppliers seem to charge a little more "because it's aviation..."
  7. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    There are lots of various dry film lubes out there. Finding one isn't the problem. Finding one that works and stays on the parts is. MISF has recently been on a kick with some dry lube stuff that paints on and then oven/heat cures. Might be made by Microlon, not sure. I'll look into it.
    One of the companies offering DIY ceramic piston coatings has a line of dry film lubes that also paint on and then oven/heat cure.
    UMWPE would be a good liner material, so would any of the Acetals (Delrin, Celcon, Turcite, etc.). I would stay away from Nylon and Teflon due to their cold flow characteristics. A glass filled Nylon MIGHT work.
    Another option might be to buy several of the replacement plugs shown here: https://reidecom.reidtool.com/xephr/edit/ITEM_GROUP and put them into the driveshaft.
  8. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    i used to work at a Tractor Supply Co. store and they carry a product called Slip Plate. it comes in a gallon or a spray can and is about like liquid graphite. i have never used it on a truck, but it works good on farm equipment's PTO shafts.
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Sounds like the cheapest, permanent solution! IMHO.
    We ship out rollers at work that get alot of adhesive on them. They come back with a baked on teflon coating that lasts a long time. Though it does wear off. Always wanted to get my frame and axles coated (never afford it though) so that red clay mud would just rinse off!
  10. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Swain is the coating company I was thinking of. Haven't looked to see if they have something applicable. It's not the DIY that I was thinking it was though. Have to dig a little more.
    For that use try PAM or a product that circle track racers use called "Mud-Off". Should be able to find it at Speedway Motors, Coleman, Port City, or AFCO.
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Thanks guys.
    For those recommending grease, that was discussed on the other thread. Most problem I've been told about by people running square shafts out here involve grease contamination, and most run dry. What I really didn't realize early on, but became clear in that other discussion, was that the "other guys" were running linked Toys and such. Not heavy full size truggies with V8s on soft leafs that bent regularly. So while they didn't have troubles running them dry, I did. That's assuming the conclusions that were drawn on that other thread are, in fact, correct. Anyway, no grease for me since that would require some sort of boot and/or wiper to prevent mess and contamination.
    And normal zircs would get stripped right off, likely on the first trip, but could be replaced with plugs I guess. But even plugs or "needle" zircs would probably get hashed in short order.
    Graphite and motorcycle dry chain lube were early ideas, but some good ones here too.
    Slip Plate sounds like it may be good, but no TSC around here and didn't find a local distributor. Thought about checking Home Depot.
    The stuff ntsqd is talking about REALLY sounds good, though maybe a "no start" since I would never get my shafts into the oven, even if the wife agreed.
    The plastic stuff is also a no start due to it's "flow" characteristics and the lack of room or way to keep it in place. Seems any solution along those lines would likely be more expensive and troublesome than building a seal or just calling up Jess (which I'll do some day).
    So far I think, graphite or chain lube is the likely winner…
  12. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Do it when she's visiting her sister.........
    LOL
    Those plugs from Reidtool.com would only require a threaded boss and could run dry. Not sure how many you'd need though. Economics might make it a non-start.
  13. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Russ, now come on. Think about what state you live in and what season is looming ahead of us and how hot black things that set in the sun all day get. Now they might need to get up into the hundreds of degrees but if they don't.....:surepal:
  14. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Dragging up an old thread I found whilst deleting subs.
    Russ, did you ever come up with something that worked?
    My new favorite stuff to use in applications like this is motorcycle chain wax. I buy the Maxima brand of aerosol. Spray it on and let dry. Goes on liquid and dries to a non sticky wax (won't pick up dirt).
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just recently got it back on the trail after a long time down, so I'm still "testing". Just received some of this stuff but have not tried it yet.
