revolver shackles ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Mar 5, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    Are the revolver shackles any good for a full size truck like a k5?Will it give me alot more flex then the shackle flips?And not to forgot are they safe? please help me on this i need as much info and i can thanks alot !
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    I have a pair installed on my 78 Sub, that was before they made them modeled for fullsize chevy's as they do now. I had to fab some hangers for the back along with a shackle flip, so it was quite a bit of work. I think ORD's shackle flip is good to go, and as far a revolver, they work fine. I drive my rig on and off, and no stability problems, and yes it helps travel. Other things to consider though, are your shock mounting position will have to be modified to get the extra travel. Basically, before you start, I would look at what you want to end up with at ride height (lift mods) and do it all at once. The rovolvers give about 3/4 - 1" lift. Good luck.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Do a search on the revolvers, another member had some pics up of his K5 with the shackle flip and revolvers awhile back. The pic's sold me.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Check this out:
    <A target="_blank" HREF=http://www.off-road.com/chevy/reviews/revolver/>http://www.off-road.com/chevy/reviews/revolver/</A>
    This is Shawns K5 with the revolvers:
    Murphy's Laws on Life :
    "Leftover nuts never match leftover bolts." [​IMG]
  5. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I considered getting these when I did my suspension rebuild, but I remember someone who had them saying that they would be MUCH better if they had a retaining pin to hold them in the closed position for street use. I remember his stating that there was more body roll through corners.
    I decided not to get them because I would have had to get really long brake lines, reposition the rear shock mounts, and plus I can use all the stability I can get [​IMG]
    Thomas.
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
  6. CarsonRoen
    CarsonRoen Registered Member
    Mar 7, 2000
    16
    WA, USA
    i was just wondering how much more articulation that you guys can get with the revolvers as aposed to the stock shackels?
