Revolver Shackles?
Discussion in 'The Garage' started by Highjaxx, Apr 28, 2002.
  1. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    Are there any revolver shackes available for an '86 suburban. I just got the shackle flip kit, and I've seen them on trucks but I'm unable to find anywhere to buy them.
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Not positive, but I think they stopped making them for full size rigs. Just out of curiosity, why do you want them?
    Depdog
  3. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Try some searching... there is A LOT of info in here already on this one.
    Ken H.
  4. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    I ordered mine from macromotive.com. The part # is TER-RXJ.
  5. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    I went to West Texas offroad and they told me that the XJ, I think, I'm not a Jeep man. would work.
    Terra flex does not show an application in their specs, but I have been told they will work.
    I think I am going to dot the same once I do the shackle flip, might want to check out ORD as well.
  6. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    Not evidence mind you... but the installation instruction sheet that came with my revolvers (back in the day when MMR/TF *did* list full size apps...) clearly said they were for "XJ" on them. Prolly the same model....
    J
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    I asked Todd at JackIt accesories here in SLC if anyone made heavy duty rear shackles for Chevy's and he said I could use Heep Cherokee Shackles as direct bolt in pieces. So you really probably do have xj revolvers. Do you like them?
    Tom
  8. Depdog
    1,657
    Georgia
    Before I used the Chevy Drop Shackles and modified them to be stronger (after crushing one!) I tried a set of regular XJ lift shackels and they were not the right size, at least not on my 77
    Depdog
  9. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I havent been able to do much testing with the revolvers actually...they are on there, but my shocks limit travel a LOT. Once I swap in the ff1b... then I can use 55willys x-member and my DT8000s will be able to really allow the revs to open up... then I'll know if I "like them" for sure. 'till then, the jury is still out. I'm a big believer in SWs idea that one should never fall in love with a mod to the point where when it doesn't work you just keep using it. If the revs suck when I hit the trail, they are coming off! /forums/images/icons/wink.gif
    J
