rewiring a grinder
Discussion in 'The Garage' started by 84gmcjimmy, Oct 24, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    How hard is it to re-wire a grinder? I mean just the plug in part. I accidently cut part of the cord, so instead of risking my safetyness, I cut it right off so I couldn't use it.
    There is just 2 wires, black and white. If I get a 2 prong plug in, and enough wire. Will all I have to do is wire it up correctly?
    I need this grinder, its my 5" and my favorite one.
  2. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Buy a plug and pull it apart. Black goes to the gold screw and white goes to the silver screw. Pretty much all there is to it. Make sure you put all the peices on the cord or you'll be taking it apart again.
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay thanks. I knew it wasn't to hard to do. I will get the parts tomorrow or sometime this week.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Well I finally got around to taking everything apart to rewire. The plug I got has 2 color recepticales for the wirre (1 black, and 1 white wire) The plug in has a light gold color (like mentioned) and on the other side it has a dark copper/brown piece. Which is neg. and what is positive for the plug in? Thanks
  5. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    ac doesnt have positive negative does it?
    as far as i know it doesnt really matter which wire goes to which
    you can flip ac cords around...doesnt matter
  6. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    wrong
    put the swap the neutral & hot on a lamp, and you'll fry yourself when you touch the lamp socket. That's why 2 prong plugs nowadays are polarized. so everything is safe. In a tool, this will keep you from putting the hot on the frame of the tool. It will still run, but its not as safe.
    put the black wire on the the copper colored screw , the white on the lighter colored screw
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay sounds good. Thanks!
  8. tecton
    Dec 1, 2002
    1,553
    WV
    wrong
    corrected /forums/images/graemlins/waytogo.gif
