RH steer arm
Discussion in 'OffRoad Design' started by mccomas, Dec 22, 2005.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    anyone answer up - easy ?
    i started installing ord cross over. as you guys know, their steering arm (passenger side) has 2 holes so you can go high steer. i am NOT doing high steer. which hole do i use for my draglink: front or back? thanks...
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    back (closest to the axle)
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    every time ive seens it its in the front hole. it offers more leverage which makes it easier to steer[​IMG]
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Why would it be any differant without highsteer?[​IMG]
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can use either hole. The correct hole is the one that is farther out. When I did my crossover I tried out both holes. I started in the hole closer to the studs. It offered a sweet turning radius, but it also gave me death wobble when I hit bumps a certain way and decreased steering power. So I moved the draglink to the outer whole and it cured the death wobble problem and gave me more leverage on the steering but, it didn't give me as good of a turning radius.
    I do credit not having as much lock to lock steering to helping me not break axles in my 10 bolt front. My wheels won't turn as far as if they were in the inside hole which is easier on the ujoints. On a D60 though that is less of an issue.
    Harley
  6. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    You'll use the front hole for the draglink, for the reasons listed above. Basically it's the one set up for the right turning radius vs. power tradeoff. It's always a guessing game to get the exact hole location on the steering arms, especially with leaf springs. There's a good bit more to it than meets the eye. The mounting points are subtly different for leaf, coil, or full hydro steering systems to make them work their best.
    Hoss, you should be getting the knuckles to the steering stops under most conditions, especially if you roll just a bit as you turn. There is some variation in how far different steering boxes will turn but you should still hit the stops most of the time.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    With the mish mash of parts that went into assembly of the crossover steering on my truck it is hard to say why my truck won't hit the steering stops. The knuckles are Jeep Wagoneer knuckles with the stops set for the Waggy, and with the small differences in center to center lengths of the pitman arm and steering arm it won't quite get to the stops. Eventually I will get around to figuring it all out but right now I am 800 miles away from my truck. Eventually I will probably buy a new steering arm with the draglink hole milled in a custom spot to work with my particuar steering setup and truck. I know that most of the steering arms produced are setup for "ballparks" or where the draglink hole normally sits with most setups.
    But for now since the steering system works pretty well and has no real problems I will just reset my steering stops and live with it till I have time and money to deal with it all. Plus it may not be worth it since I may have found a Ford HPD60 that might get swapped in. Time will tell the tale.
    Harley
  8. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    The important thing is matching the pitman arm and steering arm lengths but there are variations in knuckles and steering boxes also that don't make it as precise as it could be.
