rhino-line and carpet
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5silverado05, Jun 3, 2001.
  1. K5silverado05
    K5silverado05 Registered Member
    May 26, 2001
    20
    the k5 i am looking at buying has a pretty good interior, but i was wondering how a rhino-line (or something like it) under carpet works. i just want to line the entire inside floor and rear wheel wells and such, and then reinstall carpet over top and carpet the panels and doors? will the carpet still fit with that .25 in of liner inn there? also what liner to you recommend and should i do it professionally or myself?
  2. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    What about just Rhino Lining your carpet ?
    okay... just kidding..... yes your carpet will still fit. Why do you want to do it this way ?
    STOLEN '89 K5 - 4" lift. Found in Compton,
    stripped and dismantled.
    New Blazer on the way !!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    do herculiner, urself!!!
    its not 1/4 in thick. its pretty thin, but works the BEST.
    what u gotta do for the front [i have done my rear but not the front yet, but i knwo how to do it.] ok anyways, for the front, take out the console, seats, seatbelts [ both buckles and belts], the sill plates, the 4wd shifter, the plastic in the rar by the rear seat. and i think thats it for the front. then the carpet comes out, jsut liek that, really easy, but since ur putting it back in, there is this blackstuff, what u will wanna do is take that out VERY carefully. it will crack and break, it deadends noise and heat. then after u get that out, follow the directions from the can.
    for the rear. take out the rear seat, spare tire, and carrier and the side panels, and the rear sill plate, and then do the same thing w/ the carpet. but the carpet on the wheelwells is glued on. so u gotta use some UMPH to get it off. then the adhesive is still left. its a bitch to get off. but what i did was took a grinder to it w/ a wire brush [wear thick clothes eyeprotection and gloves to protect from stray flying brush wires] and then take that grinder to it. but make sure the stuff is shooting out the back of the blazer, or else its a mess to deal w/
    anyways. thats what i have done. let us know how it turns out.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  4. K5silverado05
    May 26, 2001
    20
    because this will mostly be my daily driver, it's gonna be my first car when im 16 and i have this awesome custom interior idea with a big chevy loyalty influence, but i am big into snowboarding and such, and will get into muddin. so when the snow starts falling, the carpet comes out. anyone have any ideas for plugs in the liner and bed so if i hosed it out of got snow in there i could drain it, thanks
  5. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    First off, fill in your profile. The herculiner works pretty good, but wear gloves and long sleeves, it sticks to everything and doesn't like to come off of skin. What year is this K5? My 1990 has stock body plugs behind the front seats for draining etc. Having already done the Herculiner thing, I think I'd just assume have it sprayed next time. It was a serious PIA.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  6. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    I have had the inside of my 90 sprayed with LINE-X spray in bed liner and love it it cost me 600.00 and it has a life time warnty I did not put carpet over it it looked too good to cover up take a look at my photo alubm
    http://www.trailblazer90.coloradok5.com
  7. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    James.. your truck looks great with the liner sprayed on...
    The door panel's.. were they sprayed also? And does this stuff come in other colors besides Black ?
    Experience is something you don't get until just after you need it. <A target="_blank" HREF=http://www.rocko.coloradok5.com>http://www.rocko.coloradok5.com</A>
  8. James90
    May 18, 2000
    986
    Rocky Mount NC
    yep door panles were sprayed to and you can get LINE-X in almost any color
    I thank i might get the out side of my blazer done in bright blue
    [​IMG]If you want to run cool
    you got to run on Heavy Heavy Fuel (106.1 RDU)
    <A target="_blank" HREF=http://www.trailblazer90.coloradok5.com>http://www.trailblazer90.coloradok5.com</A>
  9. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I would think it would still fit. You might have to trim it a little, but that's no biggy. Are you looking for rust protection or insulation? Rhino-lineing the inside is expensive (unless you go with herculiner). If you are looking for rust protection, I'd go with POR-15. If you want a little more insulation go with herculiner.It'll save some money. What I plan to do (just an idea for you) is rhino-line the back and the wheel wells and POR-15 the floor and put carpet up front. I'm changing my interior to gray and I can have it rhino-lined to match the carpet. That will still be expensive, but I don't want it black like herculiner will be, cause it's too hot here for that. Just my .02 cents. [​IMG]
    <font color=red>I'm a psychic amnesiac. I know in advance what I'm going to forget. </font color=red>
  10. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    James, is your dash sprayed with line-x also? How well did it stick? Was there any cracks in your dash before you line-x ed it? How did you prep it? Sorry for so many questions!
    thanks
    baldbandit
    "Have you outdriven a F**D lately?"
    Check out my site!
    <A target="_blank" HREF=http://www.baldbandit.coloradok5.com>http://www.baldbandit.coloradok5.com</A>
  11. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    There are drain holes in the floor, they have plug, but you have to get under the truck and bend soem tabs around to get them out. I had my carpet out a few months ago, and cleaned out a little rust. Since rust isn't a big problem in texas, I picked up soem Rustoleum and painted the floor with that with 2 coats. Put the carpet back in...BTW, if your going to put your carpet back in, don't hang it over a door. I did and it doesn't fit right anymore. Try to lay it out somewhere. Good luck
    90K5
  12. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i would advise having Rino liner or line ex or some other pro spray in done. every herculiner job i have seen chips. and easily. you can not beat a free repair lifetime warrenty. yeah, it costs more. but it is able to be almost any color. the idea of spraying the outside of the truck has been done. i have seen two trucks like this. one in full and the other just to prevent rock chips and a bra on the hood. looks sharp and no paint to wash or scratch. my two bits.... dont mind me....
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  13. James90
    May 18, 2000
    986
    Rocky Mount NC
    Baldbanbit
    yes my dash is sprayed on both sides ,it had a crack starting in one of my spaker holes but it stoped that, I just degreased it and used some stoch bright to scuff it up ,and it stuck really good LINE-X is some great stuff!
    just ack if you have any more questions
