RHino Liner or comprible liner
Discussion in 'The Garage' started by dbuda, May 9, 2005.
  1. dbuda
    dbuda Registered Member
    Apr 9, 2005
    6
    Lansing, MI
    I want coat the interior of my blazer with a rhino liner like product that i can install myslef, can anyone recommend a product and advice on where ot get it , cost, and does and donts? :confused:
  2. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    HERCULINER:deal: :saweet: :saweet: :saweet:
    the stuff rocks you can get it at your local Northern Hydraulic or off the internet ebay etc. anywhere from 70-100$ Do follow the prep instructions and don't get it on your Hootus!!!! :D
  3. tdcombs
    tdcombs Registered Member
    Apr 12, 2005
    98
    missouri
    Can you get that in any colors or just black?
  4. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I herculined mine (Jimmy, not hootus) and it was pretty easy. Came out really nice too and $550 cheaper than Line-x wanted to do the same amount.
  5. dbuda
    Apr 9, 2005
    6
    Lansing, MI
    thanks alot, by the way i am in MI are there any northern hydrolic places aroudn here i have never heard of one.
  6. bigcountryk5
    Mar 13, 2004
    931
    do a search on the net just google Herculiner and it should come up with tons of stuff.... I know they make it in grey too but not sure about any other colors and it is a little more expensive in color. :cool1:
  7. tdcombs
    Apr 12, 2005
    98
    missouri
    I live on a dirt road and when, if ever i get body work and paint done on my blazer i want to do the lower part in a liner that matches the paint to keep from getting paint chips from all the rocks that get thrown up.
  8. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I have the Rhino-Liner sprayed in mine. I do agree that it is quite a bit more expensive but it is far more heavy duty. It is a quarter inch thick and you can smash it all day with a hammer. A friend of mine has a TJ that he did with herculiner. he did 3 coats with it and within a few months of abuse it was chipping and discolored but it i guess it was doing its job just gonna need to be layed again soon. Rhino also has a lifetime warranty so if you chip or crack it AT ALL, they will either fix it or redo the whole spot. Just my .02
  9. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I had mine done from the firewall to the tailgate with Rhino Lining, it looks as good now as the day it was installed. It is tough and easy to clean, well worth the extra expense.
  10. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i herculined mine from tailgate to firewall, but its still sitting in the garage, so i cant tell you about performancem but its as easy to install as painting with a paint roller is
  11. 82dieselburb
    82dieselburb 1/2 ton status
    Jan 6, 2004
    105
    central Florida
    I used zolatone 20 textured paint on my jimmy.It is durable and was easy to spray on with a gun .It also come in alot of colors and is easy to touch up if needed.It cost about $25 a Quart. http://www.zolatoneaim.com/
  12. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Zolatone is really good, and has been around since long before Rhino. I used Durabak on the floors, rockers, bumper and grill of my Suburban about a year ago. So far, so good.
  13. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    hi, i was doing a search for durabak, and found your reply. Did you spray it on? Is it still holding up well? I was concerned about the color fading, have you seen this happen to your durabak.
    thanks
  14. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Rhino line it. Herculier is a harder compund and a lot rougher. Which means stuff will slide around more on the Hercuilner and feels like 80 grit sand paper. Oh also if Herculiner gets wets after it is applied and dried it becomes slicker than owl sh*t. Rhino has a lot more grip and is a soft compund.
    Rhino liner will hold up, a good example was when I through my 60 inch highleft in the back and there wasn't a scracth on the Rhino lining.
  15. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i herculined mine, came out real good. not too hard to clean, but once its dirty, it wont get back to the shiny color it originally was, but still looks real good.
    u can order it from jc whitney for the other colors. black is $99.99, grey, and red are both $139.99 for the kit.
    you can also get a UV protective sealant to prevent fading! im considering herculining my top, but im not sure how itd look?
    wish i had known bout the red b4 i did my interior, it would have looked real good since my truck it 2-tone black/red. o well, maybe in a couple years :D
  16. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Mine is totally Line-x'ed inside and out(even the dash).The outside is Dodge Viper Red and so is the inside exept the floor is black.Is has a new UV inhibitor in it that is guaranteed not to dull,fade,or chip forever!I had it done six months ago and it still looks brand new.
  17. Bullet
    Mar 14, 2001
    1,222
    Abilene, Texas
    Oh yeah, I had my tub Rhino'd over Four Years Ago and it still looks as good as in the pics that my Dad, Derf00 posted. I doubt the people that hercuiled thier tubs could say the same thing.
  18. Scott39
    Scott39 1/2 ton status
    Jan 3, 2005
    214
    Lakewood, CO.
    Herculiner, is the same thing as Durabak.
    The Herculiner company, is the product of durabak.
    Duarbak you can get in alot of colors.
    I used Durabak on my whole body on my FJ, but it has not been out of the garage yet.
  19. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    The durabak inside the truck is holding up good. It hasn't faded at all. I also put some on the grill and that is fading badly.
