rhino lining, over or under??
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by arq, Sep 25, 2001.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I am planning on rhino lining the inside of the tub on my blazer. I have heard/read about people also lining the top part of the bed, where the top sits on.
    Would i have any problems if I do this if I want to put my top back on??
    Anyone done this and what/how were the results??
    ARQ.
    offroad baja!!!
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>http://coloradok5.com/gallery/ArqDennis</a>
  2. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    It seems to me that as long as you made sure your bolt holes aren't covered, you wouldn't have any problems putting your top back on. The stuff is only 1/4" thick. I'd never thought of doing that and since I'm coating my bed and below the lower trim, I might as well do the bedrails too.
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    well the stuff isn't even 1/4" think unless you / they spray it on that thick. On the upper parts its usually only 1/8" or so
    Like em big and topless
    Excuse me...Would you mind removing your import from under my chevy?
  4. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    What about the top sealing on th windsheild? I don't know about all your Blazers but mine leaks like a s.o.b. and adding.125 to .250 would just make it worse. That's just my $.02
    <a target="_blank" href=http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg>http://wsphotofews.excite.com/031/rw/Jo/og/t488200.jpg</a>
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    good point, hmmm, just use silicone and expanding foam till next year, then you can add all you want, could probably add 2-3" in there
    heck good solution for that gun rack question someone had on the other forum. Stash your guns in the extra space.
    LOL
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Don't forget that moving the top higher will also likely induce leaks at the door windows...
