RhinoLine DuraLiner or Herculiner the innards?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TopOff, Mar 11, 2002.
  1. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Hi all!
    I hate my carpet!
    I want to pull it all out, including the rear side panels turn these into storage. I was thinking of some non-slip stuff. I found you can mix these with sand, but I would prefer to mix it with rubber bits.
    Anyone know which brand can do this and which is better?
    TIA
    TopOff
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    I used herculiner on mine. Pics on webshots link below. I have applied gallons of the stuff, so if you had any questions, lemme know,
    J
  3. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Is it slippery at all? What about when it is wet?
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I have my rear herculined and clearcoated over to prevent fading. Also just finished my half side panels that seal agaist the metal wall of the truck to be pretty air tight for my 6x9's and herculined those as well. It works well and I think it is a great product for a hundred bucks. Most of the other liners are a bit tougher and thicker, but way more money.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    If you use herculiner, be careful not to get it on your hootus./forums/images/icons/crazy.gif
  6. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Ok, I give up, what's a hootus?
  7. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    herculiner is pretty grippy. If its wet/muddy it can get slippery, but then anything with enough mud/water on it is.
    BTW, if you watch for sales at Napa etc you can get herc for $70-80 a gallon sometimes... its already a good deal at $99.99, but at $70 its a no brainer.
    J
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I've been thinking of doing this for my rig. How many gallons would it take to get a 5mm thick coating? I have been kicking this idea around for awhile. I wouldn't mind checking out rig that has been done first though. I saw your pics, they look good, but I like to do the touchy feely thing before I put something permanent in.
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The only thing I have to say about all this is, take into consideration as to how much extra weight you will be adding to the already "heavy metal mother". /forums/images/icons/cool.gif
  10. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    This weekend my son and I stripped the interior of the Jimmy for and preped it for Rhino Lining. I like carpet, but after removing the carpet, pad and necessary tirm, the carpet and padding are just good for trapping moisture and creating rust. My rust free Jimmy wasn't ecactly rust free once everything was removed. We had the floors, side panes, and tailgate done. We got it back this afternoon and really like what it did for the Jimmy.
    I will post some pisc in a couple of days.
  11. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    I don't think a gallon of Herculiner is all that heavy...
    Especially with my carpet and rubber backing removed.
  12. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    5mm? what is that in SAE units? I'm to drugged right now to figure it out. At any rate, Herc doesn't go on very thick. I put 2 coats on the entire tub, and then a 3rd coat on highly-used parts. There is prolly 2 gallons on my rig total, but then I have done a bunch of other stuff besides just the tub. At any rate, I put it on about 2 years ago now and haven't had a single problem with it. Even with plenty of use its never been damaged.
    I can see what ya mean about wanting to be sure before you do something "permenent." That said, herc isn't really perenent... a good wire brush attachment for a drill and some elbow grease could get it off. It'd be a pain in the butt, but it would come off. At any rate, for those of us who'd rather spend the extra $$$$ that a professional spray on liner would cost on other things, herculiner is a good option... especially if you can find it on-sale. If you are rich and don't bat an eye at spending $600+ for a professional to do the whole tub, then charge on.
    J
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    5mm is roughly 1/4". Hmmm, 2 gallons....I could do that. I guess if I didn't like it when it was done, I could always put carpet back in. I've heard that the finish is pretty rough, and if you have to crawl across it, you may get scuffed up a bit. Is that true?
    Nope ain't gonna spend $600+ on it. I do it all myself.
  14. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    In the new petersons offroad they were doing comparisons and they said that the spray-ins added about 60-65lbs. to a standard truck bed...
  15. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    Herc is rough enough that it can scrape ya if you drag a knee across it. It took me about one scuffed knee to learn this, now I just work in/around my truck with that in mind and I havent been "wounded" since. I really like herculiner, and as you said, if you dont like the look for whatever reason, you could always run carpet or rubber mats or something over the top of it.
    BTW, if you want herc to maintain its shiny-ness that it has when you first apply it, you MUST spray it with some kinda UV-pro clear top coat. If you dont, it will (like most bed liners) fade until its a SUPER flat black. I dont really care either way myself, but some people might prefer one reflectivity over another...
    J
  16. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks for the info. Nope, I don't care about shiny, just function.
  17. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    There was a thread on another BBS with a story about this guy that wasn't using gloves when lining his rig with Herculiner. He had the product on his hands and then nature called and he managed to get some on his "Hootus". The wire cup on the electric drill removal method wasn't practical for this removal job. I would reccommend that you pay close attention to the instructions when installing Herculiner, especially where it says avoid contact with skin.
  18. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Ouch...
    sometimes it pays to read the instructions.
  19. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Damn! That musta left a mark! I gotta admit though, I am wondering who was dumb enough to touch his hootus with that stuff all over his hands?
  20. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,791
    100
    Paducah, KY
    .......well, he was a Ford Explorer owner........../forums/images/icons/wink.gif.............................................
    Okay, nothing against Explorer owners, my hot neighbor lady owns one/forums/images/icons/smile.gif, but it was off some Ford Explorer Offroad forum./forums/images/icons/laugh.gif Everyone gets a big laugh out of that story./forums/images/icons/tongue.gif
    Anyone who has used the Herculiner had a problem with it peeling? I know a couple of people on <a target="_blank" href=http://www.Off-Road.com/Chevy>www.Off-Road.com/Chevy</a> have used it on their pickup beds and had problems with it. Peeling up and leaving black skidmarks on anything dragged across it./forums/images/icons/tongue.gif Both contacted Herculiner's maker about it and were offered a free kit that was supposed to fix it. Some sort of a UV protectant topcoat or something. Just thinking it would be a bi$ch to get black skidmarks on everything inside your truck./forums/images/icons/tongue.gif
