Ricer Headlights
Discussion in 'The Garage' started by k20, Jan 22, 2006.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Got my new LMC catalog yesterday, and they finally have the diamond cut headlights for the 4 headlight trucks. After a little searching, I see they are made by LMC, and they use a 60/55 watt H4 bulb. I was wondering if anyone had used these, and if so, what the light output was like? Thanks
    EDIT: Light output, and light dispersion. Ive heard of some headlights putting out alot more light, but not to the road, it was like a halo effect, lighting up the trees over the vehicle, but nothin else in front.
  2. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    I dont know how the light output on the new lights are but all i know if you should get them because they are ricer and well they will go with your APC white face guages :)
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i had em on my burban and they were ok. not much better then stock. also had some on my old 91 s10 and they sucked.
  4. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    If you want a GOOD headlight -- Then forget the diamond cut / clear lensed stuff.
    Go and find the European style H4 conversion lenses. They look just like a sealed beam headlight, except there will be a little E with a circle around it printed on the front of the bulb.
    Both Hella and Bosch make excellent quality conversion kits, and as always, you can upgrade the 50 / 60 watt bulbs that come with them to something a bit brighter.
    Locally, the Bosch kits cost about 95 bucks canadian after taxes, with the hella kits being about 120 cnd after taxes.
    Those sealed beam style lenses with the european type light dispersion make a phenominal difference! Also, while you are at it, make sure that you do the headlight relay upgrade. That also can double your light output depending on how much resistance your current headlight switch is causing.
    You can find more details on the relay upgrade at www.73-87.com :)
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh, I keep hearing about all the H4 kits, but I cant find any for sale. Im wondering if its the canada/US deal. Y'all can get em but we cant. On hella's site though, they list lenses for the round and the single square headlight trucks, but not the 4 headlight trucks. Anyone got a link to either the bosch or the hella kit, where I can buy it? Thanks guys.
  6. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Anyone got any info on the Bosch or Hella kits? I can`t seem to find anything....
    I`m looking to do this soon, but wondered if I should just get the LMC ones, and their harness, or if there was something better out there.....
  7. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    The one's you want to get are the European E-code lights. These aim the light beam down the road and to the sides - unlike the DOT pattern that kinda disperses the light everywhere. I'm running out the door now, but do some searching and you can find what I'm talking about. Believe me, the E-code lights are better than the US/CANADA light pattern. Search Daniel Stern lights and he has E-code stuff. I think the Cibie stuff is alittle more expensive than Hella (or vice versa?). E-code buddy, that's what you want.
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Is that what Hella is?
  9. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
  10. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Hella and Cibie come in both North American code and European E-code. Make sure you get the E-code lights with what ever choice you make - much better lighting. Some links:
    http://www.cibieusa.com/cibie_main_frameset.htm
    http://www.danielsternlighting.com/
    http://www.rallylights.com/hella/H4.asp#HYPER
    I think VW cars now come into North America with E-code type lighting, and same with some other import car brands. My wif's' 2001 VW Golf had the E-code style lights when she bought it new.
    Remember to upgrade your factory wiring to make sure your new lights get all the juice they need to run at maximum brightness. Easy to do. Lots of info on the web how to do the wiring. I think Daniel Stern Lighting has a schematic.
  11. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    got rice?
    j/k...i have em... love em.. they r the bosch ones..
  12. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    got a link to the Bosch ones?
  13. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I bought the Hella ones from rallylights.com I love them so far. MUCH brighter than stock. Just be warned: when/if you buy the Xenon bulbs, the bulb is purple. It lights up white, but you have a purple bulb and idiot friends like to make fun of it.:rolleyes:
  14. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh I bought the hella h4 kit from rallylights.com too, also did the relay upgrade at the same time, results are unbelievable, and Ive just got the stock wattage bulbs (Ill upgrade when one burns out) and its amazing.
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    whats the part number from rallylights, any idea?
    also, can you use the harness that LMC has for the H4s?
  16. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh I used the LMC harness, I had already bought it, and my parents got me the Hella upgrade for my b-day last yr, so I just combined em. I hadta change the high beam plug, and the low beam side comes with an adapter pigtal.
    Ill look up the p/n in a minute.
  17. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Alright if you have the older 4 headlight setup like mine, with the over/under, the p/n is H65451 and its listed under 165mm. If you have the side by side setup like in the 89-91's, I think it is HL21004 and its listed under 150mm. However, I would be sure to ask them, as those cost a fair bit more than the kit for mine.
  18. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    K20 and Col. Sanders,
    Did you guys get the E-code lights?
  19. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yep, pattern is alot better than anything DOT approved, from what I have read the only reason they arent DOT approved is b/c they dont have those raised 'dots' for aiming machines.
  20. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    Yeah, be sure you get the right size. For the people with the dual headlights, I believe it is the 165mm version and the single headlight is 185mm. Rallylights has very fast shipping and a lot of different choices.
