Rich Exhaust Code 45
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigGray89Blazer, Apr 23, 2001.
  1. BigGray89Blazer
    BigGray89Blazer Registered Member
    Sep 27, 2000
    6
    does anybody know what could be causing a rich exhaust code 45? Can't keep replacing my Cat every six months due to the fact that the engine is destroying it. I have replaced the Map Sensor, O2 Sensor new cap and rotor, new module (located underneath the Cap on the base of the distrubutor. Any info would be greatly appreciated. It is a fullsize 1989 Blazer 5.7 L V8 with 300,000 Miles on it to date
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Is your choke operating properly? I would also check the egr and PCV valve.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    its am 89 so it has tbi
    <font color=red>1991 GMC Jimmy 350tbi 3.42</font color=red>[​IMG]
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    300K miles? Wow! Anything and everything could be worn out on that rig! [​IMG] Bad fuel pressure regulator or sticking injectors are a couple of things that come to mind.
    Hooking it up to a real-time data scanner could help diagnose what's going on. Checking the block learn numbers and the integrator numbers would let you see if the computer is actually trying to correct for the rich condition. It would also let you see the TPS numbers in real time to see if it's telling the computer that the engine needs more fuel than it really needs.
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Your ECT could be telling the computer the motor is cooler than it is. Check the vacuum hose on the fuel pressure regulater to see if it has fuel in it and check the vapor canister too. There shouldnt be any liquid fuel in it.</font color=blue>
