Ride Height
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stephen, Mar 7, 2001.
  1. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Here's one for the archives and future reference.
    How tall is your suspension? Measure from the top of the axle tube to the steel bumpstop mounting plate on the front axle. Then include details on what axles you have since this makes a difference in the ride height, and what lift combination you have.
    I think this ride height number is going to be the best way to compare how tall our trucks really are. I'm ignoring the rear since it can vary more. And comes in as more personal preference. Do make sure it's sitting somewhat level when you measure, because it can affect the front end.
    Mine sits at 15", D60 axle in front, my custom springs with our standard HD shackles. I consider this about a 5" suspension. probably about 6" with the D60 added in.
    Making the world better, one truck at a time.
    SW-ORD
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Interesting...... Just for S&G, I went and measured my 2. The truck, on 4" springs (Rancho)- 3 years old measured 12" (10bolt). The K5, on 6" (Tuff Country) springs, brand new, measured 15" (D44). Does this mean my springs settled, or is 4" a nominal number. hmmmm..........
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Forgot to add- the K5 has the heavy duty shackles. Thanks Stephen, keep the hits comin.......Where else can you get quality engineering other than ORD!
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Hey Stephen, just for reference (and curiosity) I went out and measured mine. I have an old 4" Rancho lift and a 3/4 ton Dana 44 up front. Mine measures in at 12 1/4" from the tube to the bracket. I'm sure the Rancho's have sagged a bit in the 7 or so years the lift has been on though. My numbers always seem lower than most for comparison heights. Does anyone have a dead stock K5 measured for a baseline comparison?
    Rene
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Well, I just measured my (supposedly) stock project K30 with a D60. I got 10" from the passenger side tube to the bump stop bracket.
    [edited] Oh, I guess I should add, it was a CUCV with a 6.2 but now it has a 350 TBI
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.<P ID="edit"><FONT SIZE=-1>Edited by BadDog on 03/13/01 08:24 PM (server time).</FONT></P>
  6. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    Stock '84 factory everything....sloppy nasty worn out springs... 7" I was thinking you should specify what engine you are running. SB, BB, Diesel all are variables. Big old winch bumpers are another
    Luke
    84 K5
    [​IMG]<P ID="edit"><FONT SIZE=-1>Edited by Cavalry on 03/11/01 01:31 PM (server time).</FONT></P>
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    OK, 17 3/4" with 10" Superlift on my '88 crewcab dually with Dana 60 front axle. 20 1/2" with custom 12" National springs on my '77 Suburban with front Dana 60 and ORD HD shackles. 14.5" with 6" Superlift on my '90 Suburban with Dana 60 front axle.
    ken
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Keep 'em rolling in, I think this could be a good reference database for everyone.
    SW-ORD
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    1990 K5 with Dana 60 measured 15.5". I have the 5.5" BDS springs and the HD ORD shackles.
  10. I just installed a used lift kit which I believe to be a 4". I get 12 1/8" to the bumpstop- I have a 3/4 ton 10 bolt.
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  11. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I went and measured my two.The '73 Blazer with 2.5" 5 leave rancho is at 10 3/4" and The wifes '79 Sub with 4" 5 leave Cepeck is at 12".I am disapointed at the low number on the Blazer.Guess I need to stop by and pick up some shackles and the 1" lift add a leave.Since it does sit rear high.Oh yeah the Blazer as a dana 44 and the Sub has a 10bolt.Brady
    '73Beautiful Disaster <A target="_blank" HREF=http://beautifuldisaster.coloradok5.com>http://beautifuldisaster.coloradok5.com</A>
  12. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Mines at 12.5 with a4" and c10bolts with heavy duty shackles.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  13. rezalb
    rezalb 1/2 ton status
    Apr 6, 2000
    207
    Phoenix, AZ metro
    Its 9:30 pm and I had to know....Another used 4" Rancho lift installed on a 3/4 ton 10 bolt, driver side12" and passenger12-1/4" (DOH)....Stephen, I just wondering why the measurement would not be front the top of the springs where the rubber stop hits, would'nt that be a more accurate measurement? I understand that rubber stops may vary.....well, I guess the measurement should be from bumper stop to top of spring mount, or where the rubber hits the spring? That is actual movement?
    Thanks-
    rezalB
    Built for a purpose.
  14. Brady
    May 6, 2000
    628
    Parachute,Co
    He is just using this for comparision.If you used the bumpstop and the u-bolt plate the measurements would not be as easy to compare.This is due to different bumpstop IE aftermarket and due to the number of leaves in the spring pack.By using the axle tube and the bumpstop bracket this gives everyone the same exact points to measure from.Apples to apples and oranges to oranges.Brady
  15. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Mine measures in at 14"-unknown 4" springs, HD shackles, 3/4 ton D44, SB, Winch and bumper full of recovery equipment.
  16. CK5
    May 19, 1999
    21,627
    703
    CO
    13"
    Dana 60 with 4" Rancho springs and ORD shackles
    Steve - You could be more around the 6-1/2" - 7" range
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  17. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    13 ¼" with Corporate 10 bolt and 4" Superlift springs.
  18. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    I have what i think is a fairly stock 87 silverado blazer ... and a question. The springs in the front seem to bend the wrong way i.e. the spring bend up from the frame attach to the axle attach. ( they look like a ^ from the side) ... frame attach points are closer to the ground than the axle attach points. I have about 6" of "ride height." Is this normal on blazers or ar the springs shot? The truck sits with the front end slightly lower than the rear (I think it looks cool as hell). Thanks
  19. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    The factory springs have a negative arch. I don't have a stock vehicle to be able to tell you how much of a negative arch that the springs should have. From comparing your measument to the others, it sounds like your front springs are a little saggy though.
  20. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    80 blazer 10 bolt 9in clearence on passenger side 8.5 on drivers side w/broken leaf. I guess it has factory heavy duty lift.
