Ride Problem....HELP!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by vdubbin86, May 28, 2002.
  1. vdubbin86
    vdubbin86 Registered Member
    May 25, 2002
    55
    Alberta, Canada
    I got some major bumpsteer going on with my truck. Today on my way home from work I went over a little dip in the road and the truck took off to the right.(Almost lost it cause I wasn't expecting it) It bounces around alot over small bumps also. God forbid if I ever went over some uneven tracks at any speed, I'd probably end up in the ditch on my roof.
    Any common problems that these trucks have with this? I have a stab but it is probably getting pretty worn out.(Looks pretty old, but not leaking) Would replacing this help??? Or a double one???
    There isn't a swaybar on it either. I'm guessing it came with one from the factory but was removed before I got my hands on it. Should I go to the local boneyard and find one for it?
    It's an 81 K10, 10/12 bolt, 4" lift with springs in the front and blocks in the rear, riding on 33" Hankooks if that helps with the answers.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you need a sway bar i have one id sell for $20 plus shipping /forums/images/icons/smile.gif
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Do you have a raised steering arm on the left knuckle? When sitting still is your draglink flat or running down to the knuckle?
  4. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    The draglink is flat. I grabbed it and gave it a good shake and no play. Front end seems tight.Bushings in the front springs look like new. And all tires are at 32psi.
  5. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    I could probably get one at a boneyard for the price of shipping alone. But thanks anyway. /forums/images/icons/smile.gif
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Wouldn't worn ball joints cause bad steering too? Just a thought ...
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    probably true just thought id offer /forums/images/icons/smile.gif
