Ride Side Blinkers don't work...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rob71Balzer, Sep 18, 2002.
  1. Rob71Balzer
    Rob71Balzer Registered Member
    Jul 24, 2002
    6
    Colorado Springs CO
    Ride Side Blinkers don\'t work...
    I just spent an hour and a half under the dash of my 71 and I still cannot figure out why the right side blinker will not work with the head lights on. They work fine when the head lights are off, but turn in the head lights and the right blinker light just comes on and stays on. It does not blink, just sits there. Anyone else had a similar problem?
    Thanks in advance,
    Robert
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Re: Ride Side Blinkers don\'t work...
    I might just get a new flasher...Really...It was that way on my 73 ..It might work on the first gen too...mike
  3. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Pull out the flasher relay and re-seat it....for starters.
    The fact that it's only on one side though, makes me think the relay is OK. Isn't that the way that GM lets you know you have a bulb burnt out? I'd check all the bulbs on that side and make sure nothings blown.....
  4. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    My left blinker does the same.. Works fine when all lights are off but I urn on my parking lights the left stays lit, and does not flash... All bulbs are good... Did u figure it out?
  5. ashman
    ashman It's not a bronco Premium Member GMOTM Winner
    Mar 1, 2011
    3,187
    427
    salt lake city
    I've had similar problems in the past and it usually ends up being a ground issue.
    I'm not sure why it changes when the headlights are on, but try making sure the light housing is connected and properly grounded.
