rigging up a winch
Discussion in 'The Garage' started by 4trolls, Apr 11, 2005.
  1. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    I have a ramsey 8000# winch, the solenoids were gone when I got it , so I hooked it up with a solenoid from a starter but it will only go one way. My question is does anybody know how to rig up the solenoids so that it will winch in and out?
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You need at least 2 solinoids, one wired normal, one wired in reverse, and an on-off-on switch of some sort.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    my winch has 4. two in parallel each way
    warn 8274
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Winner! Takes either 4 Ford type solenoids or two purpose built solenoids to reverse a winch. Cole-Hersee makes the 4 pole solenoids, but 10+ years ago they were $30 each and had a low limiting max current.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I pulled this from the Ramsey site. It may help explain the solenoid assembly.
    http://www.ramseypdfs.com/owners_search_pdfs/Parts List-REP 8000 3.6HP motor.pdf
    btw, what is the model (exact) you have?
  6. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    I made my own...
    I used 4 ford solenoids to make a power in/out switch for the winch on my small crane on a flatbed..It took a few hours with a battery,the 4 solenoids,and a old blower motor I had,and a bunch of wires and alligator clips to figure out which way to hook up all the wires(burned a few wires till I got it right! :blush: )--then when I got it working,I got out my pen and notebook and wrote it down,so I would know where the wires go should I need to replace a solenoid...
    I mounted them in a galvanized metal box under the bed--they seem to hold up good,I've used the winch/crane a lot,and stalled it out more than a few times--the solenoids dont seem to mind,but my winch is only a 1500lb size like they use on a quad...
    Funny,I was just messing with them yesterday,had to add a new ground wire..--I have put the flatbed/crane onto a trailer made from a 62 GMC 3/4 ton chassis,since the 74 K20 it was on before is headed for the crusher very soon--my back is too--not sure if it was worth all the effort,the flatbed was almost as rotted as the truck! :blush:
    I have seen the solenoid switch assembly in the Burden Sales catolog( a salvage company) for about 35 bucks,all built and wired--I would have bought one in a heartbeat had I seen it before I built the one I made!--it will cost more for the solenoids than that--and it comes with a hand held remote switch too... :crazy:
