Right Hand Turning?
Discussion in 'The Garage' started by BlaznRebel, Mar 28, 2003.
  1. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    OK I have recently put a 6"lift on my blazer and when i did this the right hand turn is barely there. Is there a way to fix this? I really miss being able to turn right without taking up 3 lanes of traffic. Thnx for help in advancy /forums/images/graemlins/1zhelp.gif
  2. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    did you use a raised steering arm on the axle with the lift? did you lengthen the drag link? if not you might want to try one or both to get the steering box back to center when the wheels are straight.
    -Scott
  3. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    turn left 3 times
  4. BlaznRebel
    Sep 1, 2002
    115
    i used the raised steering arm when i lifted it, and is there some sarcasm there tecton? /forums/images/graemlins/grin.gif
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i kinda like tecton's idea, it's a cheap fix! /forums/images/graemlins/rotfl.gif
    did you check to make sure your steering box is centered?
  6. BlaznRebel
    Sep 1, 2002
    115
    sure haven't. I never had to center one before so not sure how to do so.
  7. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    basically you want to make sure your pitman arm is in the same place it was before you lifted it. was your steering wheel crooked after you lifted it?
  8. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, this is a pretty easy fix. Position the wheels straight forward, then disconnect the drag link from the pitman arm. Turn the steering wheel lock to lock, counting the turns so you can find the center. Now adjust the drag link so you can reattach it in the position that the pitman ends up in when it's in the middle of it's travel. Remove your steering wheel and put it back on straight if neccessary. </font>
  9. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    [/ QUOTE ]but the steering wheel is keyed, as is everything else in the steering system except for the draglink, or atleast thats what I've learned ( the hard way)
  10. SCOTTS_4X
    Mar 22, 2002
    129
    Modesto CA
    thist stuff is all fine and dandy, but if he has not put a raised steering arm on it, you're askign for trouble, let alone the fact that you're not going to get that much adjustment ou tof the drag link without it.
    -Scott
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Wha? I've used two different steering columns in my truck, the original '78 non tilt and a '79 tilt, neither one had splines that were keyed for the steering wheel. /forums/images/graemlins/confused.gif </font>
  12. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i think they started keying them in the early to mid '80's. i had an '85 that was keyed. they must have started it to make sure the steering wheel would go on straight from the factory or something. the only reason i know this is b/c i've scrapped the factory steering wheel on all of my chevy's for a smaller Grant wheel. i can't stand the bigger factory steering wheels. /forums/images/graemlins/grin.gif
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    -Scott
    [/ QUOTE ] He already said he has a raised steering arm it was like the 3rd reply. No offense but read a little of the thread before you start giving advice.
