Right way to mount a winch?
Discussion in 'The Garage' started by surpip, Jan 28, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Is there a right way to mount a winch? I have seen both types of mounting with the "feet" of the winch pointing toward the ground, and with the "feet" pointing toward the fairlead. I think the second option makes more sence but im still curious.
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    thouse are the two best ways, just think about how the stress will transfer to the bolts.
    feet to wards is best but if you had the feet faceing away from the fairlead, all the tention would be put o the theads of the bolts.
    i would ant it on the mount and sholder of the bolt.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    depends on the winch doesnt it? my 8274 is designed to mount bolts-towards-fairlead. It may not be the best way with respect to bolt strength/orientation... but its how the winch was designed and how you mount it.
    j
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Email the winch manufacturer if it's not in the directions. Some of them have pretty girly cases and if you mount them feet down instead of feet forward it may go *snap*.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    The way the 8274 mounts takes the bolts out of the equation. All they do is keep the winch from bouncing around. Though the bracket it's bolted to needs more than normal thot.
