Rim back spacing
Discussion in 'The Garage' started by 88trailblazer, Jul 10, 2005.
  1. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    I'm planning on buying new rims and tires for my truck and I'm not sure what back spacing is needed. This is mostly a daily driver which only plays in mud. I've got 10bolt, front and rear, and a 4 inch "rough-ride country" lift. I currently have 15x8 rims and 35x12.50 Mickey Thompson MTX's. (they suck in the mud!)
    I'm want to get 35x14.50 but it will probably rub. So I guess I'm stuck with 35x12.50 mud terrains.
    What size rim would I need 15x10 or 15x8?
    What back spacing?
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I would recommend a 15x10" rim for a tire that is 14.5" wide. be sure to check what size rim it needs to be mounted on. I use Tyres International as a reference for tire/rim fitment. When I had my 35's I was running a 15x10 with like 4.5" or so of backspacing and the rim rubbed the tie rod. Now I am running a 15x12 with like 2.5" of backspacing. No problem rubbing anymore.
    Hope this helps some
    James
