Rim Backspacing????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5on38s, Dec 28, 2002.
  1. K5on38s
    K5on38s Registered Member
    Dec 11, 2002
    90
    Buffalo, NY
    i just put a 14b FF in my blazer and and now im buying rims... what is the lug pattern? and backspacing im lookin for? i need front and rear.... im an unedjumucated newbie im assuming
    Front- gm Corp 10b
    Bolt Pattern-6x5.5
    Back Spacing-4
    Rear - 14 bolt gm corp:
    Bolt Pattern-8X6.5
    Back Spacing-4.25
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    That looks right, depending on how wide or in this case narrow your 14 bolt is compared to your front axle , you could run 4" backspacing on the rear to true up the trac width.
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    ff14b's are generally 8 lug... as far as I know there is only one 8 lug pattern.
    now it gets hairy and it may depend more on what you have for a front axle. Right now I have a D60 front... because I am running 15" rims, I try to keep the backspacing as low as possible, so I wont have to grind as much. If you still have your 10b in there, I dont think you would have to worry about what backspacing your rims have, anything from 3.25-4.25" would work fine. AFAIK, there are no problems with any 15" or larger rim of any backspacing fitting over the drums of a ff14... so thats not really a factor. You may consider lower backspacing though, if someday you want to upgrade to a 1-ton front end too.
    > assuming
    > Front- gm Corp 10b
    > Bolt Pattern-6x5.5
    > Back Spacing-4
    > Bolt Pattern-8X6.5
    > Back Spacing-4.25
    why more backspacing on the rear axle? On both sets of rims I have the backspacing is the same front and rear. I have used 1.5" wheel spacers in the rear to even the axle width front to rear, so I use the same type of wheel front and rear. Im not a big fan of having different sized/backspaced wheels in the front and rear... what kind of spare would you carry? Could cause issues. Anyway, if u had any other questions, lemme know!
    j
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I was reading another post of his, he's running 6 lug up front and 8 lug out back so I was recomending a wider stance in the rear to even out the front and rear trac width, he's going to have to run 2 spares anyhow with the 6 / 8 lig front / rear difference.
  5. Storm Trooper
    Nov 24, 2000
    4,640
    Question, are you going to change the front to a D60?
    What size tires are you running? 15", 16" 16.5"?
    It all matters when asking.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    [/ QUOTE ] Check with someone that has a late model Ford Superduty. For some reason, Ford decided that the world really needed another 8-lug bolt pattern. /forums/images/graemlins/angryfire.gif
  7. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    good call on the newer furd 8 lug, i heard something about that a lil while back but it didnt register until you said somethin about it. /forums/images/graemlins/crazy.gif
    at any rate, i was in a position in which i *could* have gone 6 lug front 8 lug rear and I said "screw that" and waited until i got the d60. to much of a PITA to have diff patterns front and rear imo, unless its purely a street machine... then i guess it doesnt matter quite so much. /forums/images/graemlins/smile.gif
    j
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is it 8 on 170mm????
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I don't remember the exact bolt circle, but it only fits Ford Superduty's. So in a few years there will be used 8-lug wheels for sale that may or may not fit our rigs. I can't imagine why they decided they needed to be different.
  10. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    They're FURDs they have to be different.
    Aren't they the ones that have a different tranny for each size engine? /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Everything is going metric, that's why. Ever notice that 88-98 Chevy trucks have metric lug nuts?
    I bet all 8 lug trucks will go to that Superduty pattern soon.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There's a lot more on 'em metric than just the lug nuts! /forums/images/graemlins/wink.gif But at least they still kept the bolt pattern that's been standard for years. /forums/images/graemlins/thumb.gif
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It's even worse than that! Sometimes stuff from one 302 won't fit on another 302. Ya gotta really be dedicated to start swapping major parts of Ford's. /forums/images/graemlins/eek.gif
