Rim Center Hole is bigger than the hub - Problem?
Discussion in 'The Garage' started by tocsin, Oct 13, 2006.
  1. tocsin
    tocsin Registered Member
    Dec 31, 2003
    11
    87' K5 with the stock 6 lug axles front and rear.
    I recently put a set of Centerline 15x8 rims on my K5 and noticed that the center hole on the rim isn't as small as the stock steels were. There is about a 3/8" gap between the front hub tube and the rim center hole. Is this a problem as it's being held only by the studs? The stock rims were a pretty tight fit on the front and back, so I wasn't sure if the hubs themselves absorbed some of the shock from bumps & ruts. Is this anything to be concerned about?
    Only running 235x75x15's Wild Country TXR's on it for now until I can afford a set of 15x10 chrome mod's and 33x12.5x15's. Got the Centerlines on Craigslist for $40 and had the tires lying around, so the price was right...
    Thanks all.
    Will - Boise, ID
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    They're not designed to be "hub-centric". The tapered seats on the lug holes is what centers up the rims, and as long as the lug nuts are torqued correctly the lug studs aren't absorbing any impacts.
    Rene
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Uh ya what he said:D
    Ira
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I'm still waiting for "hub-centric" II, "The Revolution" to come out on DVD! :wink1:
    Good Answer, by the way Rene!!!
