Rim Questions. 15x10 or 15x8
Discussion in 'The Garage' started by CustomChevy, Jul 1, 2005.
  1. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    Looking to mount 33x12.5x15 BFG Mud Terrain's onto my truck. Wondering if its smarter to work with 8 or 10" wide rims.
    Some tell me that rubbing is less of an issue with 10" but i'm worried about the wide tires and only 8" of rim.
    thoughts? input?
  2. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    you would be fine with 8"... but I'd go with 10" just incase you decide to bump up the tire size later.
  3. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    The 10 inch rims won't clear on my rig. They rub the fenders. I have then for when I up size. But the 8 inch clears nicely
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    My thoughts exactly.
  5. CustomChevy
    Jun 29, 2005
    4,328
    Thats exactly what i'm worried about. Since i'm on stock suspension, i think i'll probably be gettin 8's
  6. BSav
    BSav Registered Member
    Nov 4, 2002
    41
    South East N.H. USA
    re: 8in or 10in rim
    I've got 33x12.50 15 on 15x8 inch rims with a two inch lift they fit with no rubbing. My tires when at street pressure crown up in the center due to lack of rim with. I think this would wear out the center faster if i stay at the higher pressure. I saw a truck similar to mine with the same tires on a 10 in rim and the tires did not crown up in the middle, they looke evenly worn but they looked smaller on the 10 in rim. I like mine on the 8 in rim.
    hope this helps
    Brian Sav
    88 GMC Jimmy 350 2in Tuff Country 33x12.50 BFG AT
  7. Brocky
    May 22, 2005
    1,170
    I hear ya about the tires flatting out and looking smaller. How much pressure do you run on the streets? I run 32 psi on the street.
  8. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I've got 33"s and 8" rims. I think thats the way to go. If you go any wider than 12.50, than you should probably go with 10" rims.
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    15x8s are fine... you can run 44s on 'em... not sure what the problem is here.
    j
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    12.5 wide tires on an 8" wide rim,,,,,most definately
