Rim size?
Discussion in 'The Garage' started by seattle73k5, Aug 15, 2005.
  1. seattle73k5
    seattle73k5 1/2 ton status
    May 6, 2005
    210
    San diego/Camp Pendleton
    I know this has been a beaten down question but what is the best rim size for my 19.5x44x15 boggers.
    See I finally decided to go ahead and keep the tires and get 8 lug steelies for the D60 14Blt swap and just grind the calipers alittle.
    So I am going with 15x ???? 8/6.5 4"BS
    How wide should I run the rim 12" is what the tire manufacture says but wouldn't 14" wide be better?
    thanks for the inputs
  2. seattle73k5
    May 6, 2005
    210
    bump anybody? what are you all running with your 44's?
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I would really think a 14" rim would be better. If a 8"-10" wide rim is used for say a 35x12.5. I dont run anything that big mainly because then it makes it difficult to tow and haul. But you should usually go 2-4 inches narrower than tire width.
    Oh and its a pain in the azz puting the 15's on 3/4 or 1 ton axles. I have 15x10 white wagon wheels on my 73 3/4 ton. It takes a while to grind. I used a 5" wheel on my Craftsman grinder and spent 2 evenings after work grinding.
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    fit them on the skiniest rim you can get them on, then when you air down you'll never slip a bead!!
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'd go with 12's, my 39.5 x 15's are on 10" wide rims (recomended size also) and 44's have a lot more sidewall so they wouldn't pull in that much on 12" rims.
    Rene
  6. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I agree because if IIRC the recommended rim size should be about 2/3's the width of the tire..
  7. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    my 44's are on 12" rim with my beadlocks so a touch wider than that. More like 13".
  8. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    did i read 4" of backspacing, im thinkin that wont even clear. i ran 15x10s on my d60 front with 2.5" and still had to grind my calipers. i dont even think they make a readily available 15" wheel for eight lug with anything else, ive been wrong before though!! :D
    ryan
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    First thing is I would think you'd want the least amount of backspacing to keep grinding to a minimum.
    Anything from a 10" to 14" wheel should work fine.
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    My 15x10's are 3.75" BS...well 3 of them are, one is 4 1/8". I bought them used and never noticed the oddball. Ironically when I first ground my D60 calipers I had a matched pair up front. When I bought new swampers the oddball with 4 1/8" BS ended up on the front. I went for a drive and the bead area of the rim got red hot and ruined a brand new 39.5" TSL... :doah:
    Now both calipers are ground for the deeper rim.
    Rene
  11. seattle73k5
    May 6, 2005
    210
    this is a daily driver and I don't want my tires sticking way to far out of the fender like it matters with 44'" boggers but the less I get picked on by the local PD the better. That is why I was thinking 4" bs.
