Rim, Tire and Air down Question.
Discussion in 'The Garage' started by SF87K5, Aug 21, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I have 36x14.50x15" TSL radials. I am buying a set of 4 15x12" rims from a buddy of mine.
    My question is with that wide of a rim on a tirs as wide as mine. Could I run 15-20 psi in my tires will I am on the trail?
    I run mostly mix trail, rocks, mud, sand. I will be going to Uwharrie alot also. Cuz its only 1 1/2 hours from my house. Plus hopfully Tellico next year.
    Thank you in advanced for your help.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I would stick with a 15x10, but thats just my personal opinion. I have 35x15.50x15 TSL on 15x10's and have aired them down to 11psi with no problems on rocks.
  3. SF87K5
    Oct 27, 2002
    1,105
    Anyone else got any in put?
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    15 psi should be ok with a 12 wide wrapped in 14.5 ...
  5. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    As a general rule I run a size skinnier rim than is recommended for that tire. I would rather have the rock hit the tire than the rim. I run 15X8s with my 38X12.5 TSLs. I run em at 10 psi and never have em come off or get scratched but IMHO I wouldn't run the 12s. I bet they will run at 20 psi though if you want.
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Start at about 15 psi, shouldn't be a problem with that. Go down another 1 psi on each trip, as soon as you blow a bead then you know that you've gone too low. Add a couple psi on top of that number and that's pretty much as low as you want to go without the risk of blowing beads all the time. </font>
