rim + tire width
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Jan 1, 2002.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I have some 35x12.50x15 BFG AT's that I need wheels for... What is the better width option for rims 8" or 10"?..........
    <a target="_blank" href=http://community.webshots.com/user/thatguydrew23>http://community.webshots.com/user/thatguydrew23</a>
    "JEEP....SO GIRLY, BARBIE HAD TO HAVE IT"
  2. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Either is good. The tread width should be close to 9" on a 12.5 wide tire so either way it falls within 1" of rim width. Some people really like the wider look and go with 10" wides, however if your wheeling requires airing down significantly the 8" wide will help keep the tire on the rim a bit better. The narrower rim also is more protected from rocks...
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    If you are concerned with tire wear, the 10" wheels will help by keeping the tread flatter on the road. 8" wheels will tend to make the center of the tires wear faster as the sidewall is pulled in. My 35" BFG's wear completely even with 10" wheels. Try to compare the bead width of an unmounted new tire to see what it is in a relaxed state..... be sure to not get a tire that was on the bottom of a stack as it will be compressed. Generally rim width is close to 90% of section width on car tires &amp; 80% on taller truck tires. Wider wheels tend to make the sidewall stiffer (great on the street, generally bad offroad) &amp; increase steering response at the expense of increased potential impact damage to the wheel. Hope this helps.
    Lonnie
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Thanx guys.
