rim width question
Discussion in 'The Garage' started by onetonbb74, Feb 28, 2007.
  1. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    I currently have 15/39.5/15 tsl's on my truck with 15 x 10 8lug rims w/ 4/25 bs. The front tires are new with only one trail run on them and the rears were found in a backyard so they have 1/2 tread and sun damage. Anyhow, I want to run boggers in the rear and i was wondering if my 10" wide rims are to narrow for the 18/39.5/15 boggers. Do you guys think my rims will work, or do you think i need to find some 12" wide or 14" wide rims. What do you think.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    they are too narrow. minimum a 12" wheel. check www.intercotire.com they will tell you what rim size too run.
  3. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    they will work. I had 14.5s on 9 inch rim and it was fine.
  4. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    10" is more than enough
  5. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    For an 18" wide Bogger? I think that's too much tire for a 10" wide rim. I'd go with 12" wide wheels for those.
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    you can run 44s on an 8" rim... I think a 10" rim will be plenty.
    j
  7. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    It'll work I have a friend running the same wheel/tire combo on an '85 K10 longbed.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    A 10" rim plenty for the 39x18 Bogger. I have several friends running 15" wide tires on 8" rims, and tons of people run that wide of a tire on Hummers rims that are only around 8" wide.
