Rim Widths
Discussion in 'The Garage' started by spac30dyss3y, May 16, 2003.
  1. spac30dyss3y
    spac30dyss3y Registered Member
    Jan 3, 2003
    30
    Central Valley California
    How does a 15X8 in rim affect a 33-12.5-15 tire, versus a 15X10 in rim? Does the tire become less wide when mounted or what exactly? I guess my question is: How does the width of the rim affect the width of the tire? And why would someone by a 15X8 vs a 15X10 in rim? Thanks
  2. spac30dyss3y
    Jan 3, 2003
    30
    Anyone give a crap?
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    You only wainted 2 hrs...give it a day or two. I'm not sure cause I'm never run them but I'm thinking the narrower wheel would just be more protected by sidewall.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    15X8s are cheaper, marginally lighter, and generally make a tire sit a bit narrower/taller. I have my street tyres (35x12.5x15 Procomp MTs) on 15x8 rims, works great. Sometimes a narrower rim can be the difference between a tire fitting and a tire rubbing. shane74's 38.5s fit great on his rig and the narrow rims seem to be the key.
    j
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    An 8 inch rim will crown the center of the tire, causing it to wear down faster than the outside edges of the tires. Less vehicle stability is also an attribute of using a narrower wheel.
    The tire tucks in under the fenders on the 8 inch rim, whereas on a 10 inch rim, the tire will be sticking out somewhat.
  6. spac30dyss3y
    Jan 3, 2003
    30
    I got a deal on a set of used Centerline Hellcats Style 34.
    $300 for 4 in pretty good condition. They are size 15 x 8, though, and I'm trying to decide if I should go for them, or buy a new set of 15 x 10's of some other rim. Anyone know of any problems with these rims (ie the cap that goes over the lugs, etc)? thanks
