  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I need to by new rims. I bent two rims in the rollover. I ad 15x9s on the truck. I am wonderind should I go with 15x8 or 15x10? I run the Goodyear 35/12.50r15s. I do alot of rockcrawling, and I run the tire pressure down between 10 and 15 on the trail. I never had a problem with popping a bead with my 9 inch wide rims, but no one makes them anymore. Will I have a better chance of popping a bead with the 15x10s?
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  2. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    You should be okay with the 15X10s because they are a "better" choice than a 9" wheel when running a 12.50 tire. The overall "fit" is better.
    <font color=red>Impotence: Nature's way of saying "No hard feelings"</font color=red>
  3. BigTex
    Dec 27, 2000
    974
    South Texas
    By the way, that is one SWEET Firebird!
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Anybody else. I am ordering the rims in the morning.
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    the 15x10's all the way... they will even your tire stance, allow you to air down further w/o blowing a bead... and give you longer tire life!!! &lt;-- good thing!!!
  7. reddog64
    Nov 9, 2000
    3,325
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Wouldnt a wider rim make it easier to blow the bead. I have a buddy with a jeep that has 33/12.50r15s on a 7 inch wide rim and has no problems going down to 10 psi.
  9. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Not really worried about the life of the tires. I have a waranty on them and get new ones before they go bald.
  10. blazbrnc
    blazbrnc 1/2 ton status
    Mar 16, 2001
    181
    southern MI
    I'd say go with the 8" rim. The wider the rim, the better your chances of popping the tire off the bead at lower tire pressures.
    '79 K5, '79 Suburban, '76 Br**co, 77 K20
    '99 BB 4x4 Suburban to tow more junk home
  11. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats what I thought. Thanks I will be getting the 8"
