Rims are rubbing on my disc brake braket?
Discussion in 'The Garage' started by 69k5blaz, Apr 1, 2003.
  1. 69k5blaz
    69k5blaz Registered Member
    Jan 20, 2003
    35
    Lafayette, IN
    Any idea why my new rims are rubbing on my driver side disc brake braket?
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    What are the specs on the rims and axles? If youre running 15" rims on 8 lug axles, the calipers and possibly the caliper brackets will need to be ground down to fit the rim on without rubbing.
  3. 69k5blaz
    Jan 20, 2003
    35
    Lafayette, IN
    The front end is a dana 44 with 6 lug rims.
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I've seen a dying wheel bearing cause that. When the bearing starts to come apart the rotor assembly will no longer ride straight on the spindle causing the rim to hit the caliper bracket. Check it soon, it can also damage the locking hub.
  5. 69k5blaz
    Jan 20, 2003
    35
    Lafayette, IN
    I checked the hub and there is some slack when i pick up on it. I will check it tonight and i bet you are right about the bearing. Every thing else has fallen apart on this rig why not the bearings.
  6. 69k5blaz
    Jan 20, 2003
    35
    Lafayette, IN
    Is there supposed to be any play at the hub with the wheel off?
  7. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    No, there shouldn't be any up & down play.
  8. 69k5blaz
    Jan 20, 2003
    35
    Lafayette, IN
    New question. I have the hubs off and there is alot of play in the axle stub comeing out of the spindle. Maybe a 1/8 of an inch. Do i need to dig deeper?
  9. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    axle stud play is normal, but you shuold take the spindle off and check the condition of the axle shaft bearing that is inside the spindle. although that bearing does not effect the wheel hub assembly.
