Rims
Discussion in 'The Garage' started by ftcjimmy, Aug 31, 2005.
  1. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    I have a 14ff, possibly getting a 60 front and im planning on running 35"s. what size rims would you suggest? thanks
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    15" rim will require caliper grinding on the D60 for clearance. Personally I'm running my 35's on 16x8 rims. If I ever get new rims and go with bigger tires I'd probably get 17".
  3. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I have 15x10 w/ 3.5" BS on my 1-tons. Had to grind the calipers but works fine. If you don't wanna grind then I'd suggest go to a 17"er
  4. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Yes there is a reason the old 3/4 and 1 tons came with 16.5 inch wheels!! My 73 K20 needed ALOT of caliper grinding to fit 15x10's. The 14 bolt seems fine but the fronts will need alot of work. Think I spent 4 hours with a :grind: and it was not fun!!
  5. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i say go with the ole steelies. the 15x10 summit ones...good quality...
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    H2 wheels always get my vote. Cheap on eBay and sometimes here and PBB if you watch. 17" wheel.
  7. PsychoticDeadGuy
    Jan 8, 2005
    753
    i thought H2 wheels were 16.5"?
  8. cbbr
    Jul 17, 2004
    14,681
    I think that H1's are steel and 16.5", but the H2's are alumium and are 17"
  9. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    also depends on if you plan on airing down at all. a 16.5 does a horriible job at holding a bead when aired down. 15 seems to be the best but i havent heard anything about 17s yet. does anyone have any experience?
