Ring and Pinion change
Discussion in 'The Garage' started by TheAustrian, Jan 13, 2007.
  1. TheAustrian
    TheAustrian 1/2 ton status
    Jun 20, 2006
    160
    Austria
    When I am changing the Ring and Pinion of my axles, do I need to remove the complete axle and dismember the gears, or can I simply leave them mounted on the truck?
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I`ve never done a gear change, but I`m pretty sure it can be done with the axles on the truck...
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Yep leave em in the truck
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    It's easier to do in the truck, unless you can securely mount them into something else.
  5. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
  6. TheAustrian
    Jun 20, 2006
    160
    Austria
  7. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    master kit will come with all the bearings (pinion, carrier, axle), seals (axles, pinion), shims, and R&P bolts and such. This is a good route to go.
    An install kit will only come with new pinion bearings and shim kits, but most likely not the axle seals or bearings or carrier bearings. It may or may not come with R&P bolts, depends on the kit manufacturer.
  8. TheAustrian
    Jun 20, 2006
    160
    Austria
    Is an installation kit same as overhaul-kit? I assume an installation-kit should be enough when the axles are in good condition, or am I wrong?
