ring and pinion install help
Discussion in 'New England Region' started by MA87K5, Nov 7, 2006.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I am rebuilding a 12 for my blazer. Need help seting pinion depth. I have the depth tool but not sure how to use it. I searched for info and haven't found in detail on how to use it or get the correct depth. Can anyone come over my house and show me? Would like to get the rearend under my k5 b4 it snows. Thanks
  2. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    my friend knows how to use that tool. ill give him a call tomorrow. he can tell you what to do.
  3. DirtyJim
    May 4, 2005
    665
    San Diego
    he only checks the backlash, sorry.
  4. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Thanks for checking
  5. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Can anybody help me?
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    West Coast Differentials has online instructions.
  7. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    They don't show me how to get the correct pinion depth using the depth tool. I just need someone to put me on the right track by showing me.
  8. DirtyJim
    May 4, 2005
    665
    San Diego
    did you check it with that paste to see if the pinion is sliding deep in the ring? thats what i did when i put my locker in and set the backlash.
  9. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I think I may have the wrong gears for the carrier. I had 3.42 gears on the carrier before and I went to 3.73 gears. What are the thickness of the ring gear supposed to be?
  10. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Would anyone have a set of carrier bearing caps that they will give up?
  11. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I think (?) carrier caps are married to the carrier, not interchangeable, I'm not sure on that. Thats the reason all instructions make a point of returning the caps to their original location and orientation. Just like rod ends.
  12. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Could I be able to install new caps?
  13. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Can anybody answer? Thank you
  14. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Finally found it using search. How much would I expect to pay a machine shop to hone the housing with the new caps installed?
  15. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Don't know if you can even get oversized bearings. I'll check my factory shop manual this afternoon, to see what they say about repair of a damaged diff.:D
  16. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Thanks for everyone help. I talk to a shop who all they do is diffs and he told me that I might get lucky finding a set out of at least 10 sets. And the caps that summet sells need to be machined and that cost is around $200. So I calld some people in the classified paper and found a whole 12 bolt truck rear for $125 so I'll get that one. Then I'll be a few steps closer to completing the rearend rebuild.
