ring and pinion q's
Discussion in 'The Garage' started by dheavychevy38, Nov 27, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    ring and pinion q\'s
    does any one have the specs for a ring and pinion install for 10 bolts??
    any advice or ideas to make it go better?
  2. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Re: ring and pinion q\'s
    Get a shim kit for the bearings. That is for backlash (about .004 to .008). The movement of the ring gear back and forth when the pinion is held. Then check the gear tooth contact pattern with some assembly lube or equivilent. Check out this site for more info web page
  3. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Get a full intall kit. Bearings, seals, shims everything. will even come with instructions. do your research first so you know whats ahead of you.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    find someone very knowledgable in how to set up GM axle gearsets, and that has the proper tools
    where in IL are you at?
  5. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i'm in algonquin IL by crystal lake
    i was going to put in my 5.13's but forgot to get pinion bearings so they will have to wait
