Ring and pinion
Discussion in 'The Garage' started by mrcold, Jun 21, 2004.
  1. mrcold
    mrcold Registered Member
    Jun 6, 2004
    37
    North of SWEDEN
    How’s the ring and pinion marked for a 4.10 gear ratio and how many teeth should I count to for that gear ratio. Dose it make any difference what type of axels it is?
    Tanks
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    You divide the number of ring gear teeth (41 or whatever yours is) by the number of pinion gear teeth (10 or whatever) and get your gear ratio. 41/10=4.10 /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Yeah like jeff said, if there is 41 ring gear teeth, and 10 pinion teeth, you have 4.10's /forums/images/graemlins/thumb.gif
  4. mrcold
    Jun 6, 2004
    37
    North of SWEDEN
    Right!
    Wasn't harder than that! /forums/images/graemlins/thumb.gif
    Thanks for the help!
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    If you ever get stuck, just divide the small number by the big number, and then you find the gear ratio /forums/images/graemlins/waytogo.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    41 and 10 for sure for at least 12 and 10 and 14 bolt axles and dana 44 and 60's too, i dunno on other modlds beyond that
