Ring and Pinion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dman69, Apr 12, 2002.
  1. dman69
    dman69 Registered Member
    Feb 20, 2002
    7
    Massachusetts
    i am going to change my 3.08 gear ratio to 4.11 or 4.10 to run my small 35's, i was doing this so that i could put bigger tires on it someday. is there anything i should know before i do this?
  2. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    what size so you plan on getting in the future?
  3. Blue Meanie
    Apr 12, 2002
    61
    southern New Jersey
    what size so you plan on getting in the future? and what kind of power are you making? i only have a 305 and i am running 39.5's with 5.13's to make up for the underpowered almost dead engine. also, how do you use your vehicle?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    4.10's are OK for 35's but if you plan to go to a bigger tire in the future, save yourself about a thousand bucks and put in the right gears for the next tires now. /forums/images/icons/cool.gif
  5. RockBurb
    RockBurb 1/2 ton status
    Jul 30, 2001
    106
    Moscow Idaho
    I have 35's on my suburban witha 700r4, and Im running 4.56, and its great. I would personally go 4.56 so then you have some flex room in the future.
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    do 4.56's you wont regret it.. it's like adding an extra 50 oponies to your motor... so to speak...
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    With O/D, I would go to 4.56. with a 3-speed, stick to 4.11. I have O/D with 35's and 4.10's. I turn 2000rpm on the freeway, so it's definately not too low of a gear.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If you have a O/D trans then go with 4.56 gears. I currently have 35's and 4.10's and it is not enough gear for the trans. The trans wants to "search" between 3rd and O/D. This will burn up a 700R4 real fast if not careful. I have 4.56's ready to install now. Even if you have a TH350 or TH400 I would still go with the 4.56's if you plan on bigger tires in the future. I ran TH350 with 35's and 4.56's on my last rig and it worked out well.
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    If you've got a 700 4.56's are great. A 3spd then 4.10's would be a better choice...
    Jim
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    4.56's all the way
  11. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    forget that if youre going up to a 39 or similar in the future for the 700 to be in optimum rpm range you need 4.88s...i know cuz thats what i just put in mine for 39 boggers
    Later
