!@$#@#@ Ring Gear Bolts
Discussion in 'The Garage' started by rcamacho, Jan 29, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Holy @#@# batman! I've got my 1/2" impact gun going full bore at 120 PSI and only 3 bolts have relented. How the heck do you get these buggers off?
    1) I do not have a bench or vice.
    2) I've tried a pry bar in the cross shaft hole for leverage to no avail.
    Heat?
  2. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i had to use a bench and vice, dang near busted a gut prying on it. iv been told heat works but never tried it.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    They are installed with red loctite so heat or about 500 lb/ft of torque should bust them loose:D .
    Ira
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    I braced the carrier a bit differently and was able to break the bolts loose with a 3" breaker bar. Ug.
    Well, the lockright is now in the carrier and ready for re-installation...
  5. lamberthkp
    Jan 17, 2005
    1,468
    16
    West TN
    good to hear! GIT-R-DONE
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I break them loose while it's still in the diff housing, and use a long breaker bar, never really had an issue with them
  7. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    have your little brother twisting a ratchet around and asking how much longer its going to take. By the time you get the diff out, the ring bolots just come off :angry1: :pimp:
  8. 4xcrazy
    Oct 31, 2003
    9,471
    5
    WHAT ???:confused:
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Dana axles , of all the things to do , make it so you have to remove the carrier to put in a lunchbox locker , damn roll pin :thumb:
  10. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    HAHA...I would snap:haha:
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    how much torque does your 1/2 impact putout? if it is a cheapie you might just need a more powerful impact. my ingersol rand puts out 450lbs torque, mine came right off and they were factory installed bolts. just my .02 cents.
